CORRECTION - The reflector I used wasn’t a C8 reflector, but rather a 36mm one from FT: https://www.fasttech.com/p/1208514.
Hi,
I just received one of these today from Fasttech (from an order):
https://www.fasttech.com/products/1700404
I was interested in it because from the FT pics, it looked like it was a mechanical side switcher (rather than electronic, so no parasitic drain), plus it looked cool in gold, and it was pretty cheap.
After I got it, I disassembled it (naturally):
As you can see, it’s not bad. As mentioned above, and confirmed now, the side switch is mechanical.
The pill is fairly roomy, albeit hollow, and it screws into the head from the battery end, so heat transfer should be ok. There’s an “attractive” alumin-ish bezel ring (not glued) and glass lens (not AR).
One bad thing is that the SMO reflector is plastic.
I wanted to mod it, and I debated what emitter to put in, but I finally decided to replace the emitter with an old XM-L I had:
At the same time, I wanted to see if I could replace the reflector.
It turned out that I have a bunch of different C8 reflectors that I bought from FT awhile ago, and one, literally, was just a drop in replacement for the original reflector (I also used one of the ‘butterfly’ type of insulators from FT)… so this light is really a kind of cheap C8 clone with a side mechanical switch and an aluminum bezel.
It’s somewhat longer than a “real” C8, because of the length that is added by having the side switch in-line with the battery tube, but not that much longer.
I really should’ve replaced the original driver at the same time (it’s press-fit into the battery end of the pill), but was kind of lazy… a job for another day.
Anyway, here’s a whitewall shot (about 1.5 meters) of high now after the XM-L:
