Wow all I can say is wow OK, very impressive nice job. I am having trouble stacking those chips so I ordered a better soldering iron and maybe I will finally be able to do it.
The commercial version is just 35mm longer plus 10mm larger in head diameter though with LiMn 18500s. 2 cells @ 2.5A, converted that would be 5A if comparing to your case.
would you mind telling me which lens did you use - 19° or 25° ? Probably you purchase leds and lens from items from http://www.led-tech.de. This is actualy my intension, but use different wireing. Can make a photo of yours?
For paralell driven leds what batteries did you use?
Can you direct me to some LiMn baterries you use? Links would be the best.
I'm going try to use 8,4V (2S2P) pack, so i need different wireing and driver. We had some discussion about that in this thread https://budgetlightforum.com/t/-/2816 from #10 onwards.
