Bro, so how's your SR 3xT6 status with Manafont, fixed it?
Most definitely this is much brighter with much more current to the emitters. In fact if you are very sure that you are going to be operating in sub-zero temps, you would reap the full benefits of the 3A driver. There is a lot of meat left for XM-L at 3A, just that you need to actively pull the heat away and just having a big block of aluminum isn't enough. Anyway there is always medium power.
Hehe I'm from Belgium too, being tossed between the sky ray and now the DRY. Shipping form CN is how much? because 55$ 80+$ will be a huge difference so it has to be worth it.
Could this light been driven with trustfire flames?
Is it easy to hold (I have rather small hands :p)
How is throw/spill compare to sky ray
Difference except for color between cool and warm white?
The CW is $76, not $80. MF uses unregistered Air Mail, and Air Mail from CNQ site I see here is $9. Go for EMS or DHL, $13 and $16. Register an account and you'll see it in Checkout.
I'd advise not driving with Trustfire Flames for these 2 and 3 cell lights which take in quite a high current at a certain point. Mine always stays somewhat balanced during discharge but not as close as I'd love to, as in not within 0.01V. Understand that these are not exactly your regular flashlights and a degree of discipline is needed for both runtime and cell handling (same goes for lasers). But it's good, that's why it's called a hobby.
PS. Both lights, this Dry and other Sky Ray/Trustfire/Fandyfire variants, they need to be fed good cells. For the SR/TF/FF, it is regulated in the sense that if your cells voltage sag it would pull more current. The higher current triggers the cell PCB protection. For this it takes 3A or 4A give or take. If your cell is unable to provide that juice, it also triggers the protection. A UF-980L triggers some of my cells PCB protection but not the Solarforce/Xtar/TF Flames. Anyway XTAR 18700 fits, very tight fit but it is ok and fits somewhat tightly in the tube which is good, absolutely no rattle.
In short, this is a product which is really a pocket rocket. It fits in the pocket, and basically the same thing as those customs. You need to know what are the operational characteristics. Eg 9A 1-cell LiMn https://budgetlightforum.com/t/-/2853 In fact this DRY 3 XM-L packs more battery power (runtime etc)....and the CW is eating 4A.
Mmm more expensive lights, more expensive cells ... :)
Could you link me to a site where they sell cheap yet good batteries? CW can only use unprot batteries unless they are really good like AW there is stated, but 15$ a battery is way over my budget ...
Search the group buy for XTAR 18700 2600mAh. It is just usd13.50 shipped for a pair. Basically they are Sanyo 2600s. Not sure if it is still valid, the end date is 31st July.
You need to be very careful with the TF Flames, probably do a reading before discharging and another reading after discharging to see if they are balanced.
It's a brandname i never heard off before myself, but i'm still quite new to the flashlight scene :). Now they also have a 4 mode which features low med hi strobe.
3 mode draws 4A current on high, 4 mode 3A on high, don't know if this will make a lot of difference lumen wise.
I'm going to buy cold or neutral version, but as i don't own neutral ones i don't know what to expect. Also going for 4 mode with 3A at high but don't know what i have to expect compared to 4A on 3 mode.
I have the Warm White version, and it is a very impressive torch. Build quality is top-notch, as is the anodizing. The battery carrier is a bit weaker than the rest of the light, but perfectly serviceable - and able to fit the longer 18700 XTAR protected batteries.
With some unprotected AW IMR 18650s the currents were:
High: 3.01 A
Med: 0.51 A
Strobe: 1.42 A
I am very happy with this one, and will likely purchase the Neutral version as well.
I'm doubting between cold and neutral. Warm would definetely be to orangish for me, but I dont really know what i should expect from neutral since i never owned such a light.
