Review: JAX Z1 (1x XM-L2, 1 or 2 x 26650/18650)
Thanks. Which is a better buy in terms of quality and throw? This or the UF-1405?
The Jax is built better but has around half the lux when compared to the 1405 if both are running xpg2s at 5A.
I meant stock.
My 1405 had 68klux stock whereas the Jax has 50klux.
I like the jax better, nicer and better quality imo, but the smaller thwart numbers, and specially the price difference (due to MAP policies, just remember that fight BG-GB…) made me go for the 1504 group buy, approx halving the (discounted) price of the jax. Even the 2 cell 1405 complete light is 5$ cheaper than the (also discounted) jax z1 host
If the lumens double, will that double the throw?
What would anyone estimate the throw on this one? 300m? 500M? 700?
http://www.ebay.com/itm/JAX-Z1-Cree-XHP50-Zoomable-2400lm-8-Modes-Flashlight-/331566155574?
Double lumens definitely doesn’t mean double the throw.
Need to know the lux to work out throw distance
Thanks. Duh, don’t know what I was thinking. But double lumens could be what, 1.5x the throw?
Am sure it’s better built, but wonder how it compares in throw and lumens with this one. (2000 Chinese lumens…it DOES use 2 - 18650’s.)
http://www.ebay.com/itm/151554288976?\_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I have the MC-E zoomie from way back when and it leaves the + sign in the die, so don't count on throw. Lumens, well, there won't be a competition to most lights on the market, even assuming it isn't driven to capacity, but that will NOT satisfy the throw-hounds out there.
I emailed hkequipment and they responded quickly.
Said the throw was about 500m on this Jax Z1 2400L.
My 55kcd measurement of the xml2 version converts to 469m. So they’re about the same throw, but the xhp50 should have a larger hotspot with the signature plus sign through it and a heck of a lot more heat.
Lumens and throw are mostly unrelated. For example consider a light bulb, which has high lumens and almost no lux or throw, and a laser, which has barely any lumens but has high lux and throw.
So, for throw it’s all about lux. However, double the lux still doesn’t mean double the throw. It’s a square root relationship, so four times the lux is needed to double the throw. Here are a few throw distances and the lux needed to get them:
  • 50 m: 625 cd lux
  • 100 m: 2500 cd lux
  • 200 m: 10 kcd lux
  • 300 m: 22.5 kcd lux
  • 400 m: 40 kcd lux
  • 500 m: 62.5 kcd lux
  • 600 m: 90 kcd lux
  • 700 m: 122.5 kcd lux
  • 800 m: 160 kcd lux
  • 900 m: 202.5 kcd lux
  • 1 km: 250 kcd lux
  • 1.5 km: 562.5 kcd lux
  • 2 km: 1 Mcd lux
For throw, a de-domed XP-G2 usually works well.
If I recall correctly, the XHP-70 is basically four XM-L2 dies all placed together under one dome. The XM-L2 is a 2mm die (3mm apparent, with dome on). The XP-G2 is a 1.4mm die, or 1.9mm apparent with the dome. So, the math works out like this:
  • Two XM-L2s appear 6mm wide.
  • A de-domed XP-G2 appears 1.4mm wide.
  • The XHP-70 is rated for 4022 lm.
  • The XP-G2 is rated for 537 lm.
  • So, XHP-70 has (6 / 1.4) 2 or 18.36 times as much surface area, but only 4022/537 or 7.48 times as many lumens.
  • 7.48 / 18.36 works out to about 40%, less than half the surface intensity.
So, going purely by numbers on Cree’s spec sheets, the XHP-70 should end up getting less than half as much throw compared to a de-domed XP-G2, despite putting out 7.5X as much light and using 6.5X as much power. Additionally, we’ve found that the XP-G2 can put out significantly more light if overdriven, so the difference in throw is probably even more.
A de-domed XP-E2 or XP-C could theoretically throw even better since they’re smaller, but in practice it hasn’t worked very well and the beam usually ends up too laser-like.
Nope.
You cannot measure the from from the total output. The throw depends entirely on the light output of the die PER SQUARE INCH/MILLIMETER.
Yes, the XM L2 reaches far mor Lumens then the XP G2, but the surface of the die is much larger as well.
In other words: the smaller and brigther the lightsource/die, the more throw you can achieve.
Grtz
Nico
Unknown: Thanks, so they were being pretty accurate when they said 500m
ToyKeeper: 4x the lux to double the throw. Nice. And thanks for the great
table there.
Nico: thanks…the smaller the brighter the light source.
I got lost there, what is this XP-G2??? Is that an EagleTac?
(which I could see a comparison btw this Jax Z1 and the AceBeam K60.)
Just modded my JAX Z1, finally. Did a gas de-domed XM-L2 U4 1C on 20mm Noctigon. Resistor modded the stock driver by adding a R120 (an R075 produced too much current at the LED). With the R120, I got 2.8A at the tail, and ~4.7A at the LED, measured on the bench with 2 cells. I'm running two KK button tops.
I got 216 kcd measured at 5m, which is 930 meters. Distance is based on the amount of light equal to moonlight, which is 1/4 candela, so you take your candela, multiple by 4 (or divide by 0.25), then take the square root of that.
It's all spelled out really well here: http://flashlightwiki.com/Light_Output_Measurements
For me, I'd take little less power, same throw from an XM-L2 as a XP-G2. Plus in full flood, I measured 1309 lumens @start, 1268 lumens @30 secs.
@RoyWalker: A XP G2 is a Cree Led type.
Cree has quite a number of Led dies, each with specific datasheets:
XM L2: Cree XM L2 datasheet
XP G2: Cree XP G2 datasheet
Cree die sizes
As you can see, the XML has - what - four times the surface of the XPG? (the surface of the led itself, on the die that is)
Grtz
Nico
So -will this throw about 500 meters and can it be ordered this way ?
Do you get the great white laser effect from the tight beam and high Candela?
@Robertkoa, suggest you look at:
UPDATED 23-01 Group Buy CPFItalia Cometa
https://budgetlightforum.com/t/-/37235
Best Regards,
George
What is the throw on that ?
In boost mode with that LED how far with a de- domed would you estimate the throw ?
This is what I hoped Cometa would be [ with your mod ].
How much do you think the Modder will charge me ?
If it’s great throw …I may have to buy 2 and let Modder keep one even…
Thanks.
