I never have any power connected to the driver when I flash. This may however depend on driver design. I have noticed that capacitors directly on MCU pins can interfere with flashing. If the driver is powered it would have an off time cap charged, and therefore not quickly short on first flash attempt.
I had to move an off time cap to another pin once. I guess I could have tried flashing with the light on before I moved it but I didn’t think about it at the time. I just moved it and have since then always put all voltage input stuff on PB4, works fine for ATtiny85Vs at least.
I just got a whole stack of qlites in the door today, and am wanting to program them. I would prefer to get the hardware from Digikey if possible. Does anyone have part number or good search material for the USBASP, clip, and wire bundle? Shipping from China takes a really long time to Canada.
I just erased the ATtiny13A of the BLF A6 17DD driver using your how-to.
Maybe it’s posted here already, but my ribbon was wired the other way around. The coloured strand on the ribbon, is ribbon #1 (MOSI) instead of #8 on your specimen. So i just colour marked every strand with a sharpie, and followed you how-to from there. Works fine now, the test in AVRdude passed!
hi I just recevide all the components for flashing attiny13 but i cannot undurstend how to connect the programmer (10 pins) with the Soic8 (8 pins)
some photos aren’t avaiable and maybe there is the answer to my problems
Can't leave me out of this one... Been meaning to take updated pics of my setup. Looks like I'm matching TK's exactly, just using different colored cables. Here's pics of mine, showing a couple of my favorite, most commonly used tools as well.
and simply peel off a 6 wire section, save the rest for a backup.
I updated that flashlightwiki page for the proper USBASP V2.0 wiring. The change to using Pin 10 on the AVR programmer side for ground solved a few flaky problems I was having .
I've said this before -- Please note the wiring pin-out details is wrong in the OP - don't use pin 4 for GND on AVR USB programmer side: use pin #10 instead, as our photos show.
Also, this colored ribbon cable is much easier to work with than the typical gray ribbon cable in the OP. I know from experience - I evolved from the gray to the colored stuff - very easy to swap around pins, easy to trace the unique colors.
I believe post #2 shows the wiring as you’ve described Tom. Should the grey wire scheme be ditched altogether and only the Pomona/ribbon cable combo recommended? It’s been a while since I’ve used the original cable, but it worked until, I think, the clip started malfunctioning.
Ahh, ok, missed it there. Well, it's just easier to work with the colored ribbon, having the individual pins, and available from FT and other sources cheap. Forgot who recommended it first originally, but some one definitely did before me.
thank you all, just one question, I have the fasttech programmer and I would use the connection of the programmer
How I would cut and select wires?
is the dotted one number 1 or 10?
how can I know the cable/pin courrency for choose them? (e.g. top left pin is the first cable? top right or second left is second cable and go on)
Please only look at the pin numbers. For wiring to the clip, look above at Toykeepers post #125 or Tom E’s post #127.
So the right upper pin on the programmer is pin #1, below that #2 and on… Search for the little triangle on the programmer. This is pin #1, the red wire in post #125 and the brown wire in post #127 of this thread.
Sorry, I don't think I was clear. The pictures and labeling on the MCU and clip side are all good and accurate, just the inset diagram of the first pic in post #2 is wrong, and the last two pics in post #2 aren't showing for me, so can't comment on them.
Oh, and yes - I whole heartedly agree the original gray ribbon cable should be discarded, and the colored ribbon used/shown. It's just sooo much easier to work with, and cheap, and available from several sources. The gray cable can still be used of course, but working with those ribbon crimp on connectors can be difficult. I know for me, I got help from a tech @work to do it, but the color ribbon cables requires no tools, no crimping, etc.. Anyone should be able to work with them.
Any help is appreciated - I’m stuck at trying to install the libusb-win32 drivers on my Windows10 64 bit laptop. I got my usbasp plugged into the usb port, I can see the device in the device manager but I can’t install the drivers. I ran the install wizard after I extracted the files but it then says windows policy won’t install unsigned drivers. It mentions this on the libusb-win32 wiki page, but I still can’t find a solution that works. What am I missing?
Yep, some don't work. I did get mine working, but since then, my Win10 notebook died, unrelated though. Pretty sure I dnld'ed mine from here: http://www.protostack.com/accessories/usbasp-avr-programmer. They claim there it's fully signed.
I’ve got the cheapo clip and cable setup, but I’ve been able to program the BLF FET+1 A17DD-L (from Banggood) with much success.
Well, I went to assemble some lights using the Qlite from Richard and thought I’d give a shot programming those as well. I can’t get avrdude to communicate with the Qlites properly.
I have everything wired up, and I execute the test command (below) and I get an error saying that it has the wrong device signature. I thought perhaps my clip got messed up, so I double checked all my wires. And some searches indicated it could mean a dirty clip, I wiped everything down with rubbing alcohol. Tried again – no dice. I then hooked up a A17DD-L and tried – it worked! Swapped back over to the Qlite, still not working.
The command I’m using to test (I’m on Linux):
sudo avrdude -p t13 -c usbasp -n
The output from the A17DD-L:
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructions
