I found that set up to be too tricky for me… Though others have managed to make it work. my feeble mind quickly got lost in all the same color wires. and you will have to not use four of them, but I cannot tell you which four not to use or how to hook them up on the USB programmer.
it might be worth the money and headache to get some colored cables and unsolder the gray ones from the clip and then solder the colored ones on to the clip to correspond to the pictures.
This is exactly my problem. It is SO hard to not lose the overview and constantly think from the female and male connector perspective. I’m just done with pretinning the cut up 10-pin wire…now I need a cigarette first.
I did do it the other way around. I soldered on the clip and left the 10-pin connector untouched. I’ll go over it one more time, but I’m pretty positive I got it correct.
It actually worked. Can’t beat the feeling of succeeding with something you have absolutely no clue of. AVRdude says I got anduril on my D1.
Got to put that thing together quick. I only trust this, if I see it with my own eyes.
Edit: And the light is up and running! :sunglasses: :+1:
I put Anduril on my D4 and it’s awesome, but sometimes it just flashes when I press or press/hold the button.
The light didn’t do this before and I’ve tried very firm presses to eliminate the switch as the culprit.
Does it with different batteries, fully charged, slightly discharged.
More often does it if I haven’t used the light for a while.
I grabbed the FW out of the index of/torches/fsm. There are a few versions of the FW listed there, were there design changes to the D4 that these different versions address?
Even if there’s no fix it’s staying on, only a minor inconvenience.
My wife and I go to sleep to candle or sunset, thanks for all the fun stuff you’ve included!
Only problem is now I have to figure out how to put it on all my lights.
Bonus: now I don’t agonize over the FW3A. Main interest in that was the firmware. I’m still in but I’ve got my Anduril fix.
That’s very strange. You mean, it flashes in the same was as when you first insert a battery? If so, that would indicate that the MCU is rebooting. There could be a short or something loose/exposed inside, or there could be a firmware bug.
I haven’t encountered that behavior, and no one else has mentioned anything like it, so I’m guessing it’s more likely to be a physical issue instead of a bug. However, that’s not certain.
I just grabbed the hex file for the D4 from toykeeper.net and flashed it.
Yes, it just does a battery flash. Happens on quick click or hold for low.
Battery connection is good, runs turbo no problem.
Doesn’t do it all the time, but sometimes if I haven’t been using the light it will do 2 in a row.
I’ve tried to recreate it by doing a “weak” click, this switch seems very well made because I can’t trick it. I’ve had other lights where if you went at it slightly off-axis it wouldn’t register the click but not the Emisar.
I will make sure I’m running the release from 8/22/18.
It wouldn’t surprise me if I screwed something up. This was my first attempt and I was giddy with excitement.
I’ve already got it on another driver that I’m putting in a cute little Sunwayman C10R.
If you do anything to it, let me know how it goes. If something is weird inside, it might be sufficient to just loosen the battery tube, wiggle the driver, and tighten the tube again. Of course, that could also make things worse…
Is there Anduril available for the Haikelite MT09R? Couldn’t find anything.
By the way, what is sunset mode on Anduril? Is there a more detailed explanation of the UI than the cheat sheet?
I got this message after installing zidar too:
avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor=‘www.fischl.de’ product=‘USBasp’
