Colliedoggy, the taps (at config mode) make the led flash to indicate you have reached mode group selection, then you do the required number of taps to select the mode group, then the led blinks to show it has registered and then it will blink again after a pause so you can set mode memory on or off.
Correct?
I got that from the diagram ToyKeeper, but I have been reading much worse diagrams and explanations for years and having to make heads or tails of them. Your diagram looks great, and I understood the click? in between the blinks on the config mode.
Perhaps an arrow pointing to a Click Now if you want to change modes oval in between the Blink representations would be clearer for those not used to reading diagrams? Great job overall, Thanks!
Well, i am 99% sure they wont use 3D bin: its quite spendy and rare
Actualy nearly every time that i bought a FL with a neuthral light it came with a greenish tint, even S10 Barton/ or M2X/M21X…on second thought its maybe every time, especialy with an AR glass: like X6 for instance,so i`ve decided not to buy those anymore but CW( for dedoming) and i use my own emitters afterthat
Fenix PD60 had good 5000k tinted emitters inside by default though…
A minor issue. I understand the above instructions fine, but it might be confusing for some. If it blinks twice, you are already too late to switch of between the blinks. And you will set the mode memory instead.
It might perhaps be clearer and simpler(?) if the software was updated to something like this:
2. After a brief pause, it'll blink once. Turn the light off directly after this first blink to toggle the mode group.
3. Otherwise, wait for next blink and turn the light off directly after this second blink to toggle the mode memory.
4. If you don't do anything the light will return to the regular mode without any changes to the config.
“Well, i am 99% sure they wont use 3D bin: its quite spendy and rare”
Why so rare? - Perhaps the reason for the additional cost is because the 3D tint is not designed as such, but is a ‘mistake’ made while shooting for another tint? - Seems to me though, that if they know how to make a 3D that it would be just as simple to make more, as it is (for instance) the ubiquitous 3C.
I have two 3D tinted lights, both the same model bought a few months apart, three years ago. - Both have the same tint to my eyes. - They are Budget Lights with “spendy, rare” emitters :-)… Romisen, with XPG -R5.
They have the Very Best tint of all of my lights.
So my Question: If Romisen (a budget light) can use a 3D, why then can’t EE use it for our ‘Special’ BLF A6?
It would seem to me, that a Large buyer like BLF should be given this consideration.
Not everyone will agree with my choice in a NW tint, of course, but do we really have to just take “run of the mill”, or whatever they have in stock, or can get cheaper?
You would not be too late; the window for pressing the button is actually a bit longer than that:
The light turns on, signalling the start of the window when you can click to change the config.
100ms pass.
The light turns off; 400ms pass
The light turns on; 100ms pass.
The light turns off; 400ms pass.
The click window ends.
1000ms pass.
The process repeats, but with a different setting.
So, the text and diagram suggest clicking between the two blinks, but it works fine if you click during the second blink or even a bit after the second blink. It’s not like those 3/5-mode nanjg drivers which only give you a split second to respond. I tried to make it easier and more forgiving for people who don’t have lightning reflexes.
That is a good idea & strategy Mitko :), to pick the CW emitter for dedoming salvaging, when we plan to upgrade the LED anyway, i will keep that in mind
