Who knows? Output at specified currents and the thermal resistance are pretty much the same, so the question is what happens if you overdrive them :smiling_imp:
Edit: and if they perform: the million dollar question is: will they dedome?
Very interisting this Luminus SST-40! If i can read right we can use a XM MCPCB with this led. But the low voltage (voltage bin vj= 2,7-2,9V) and the high amps (5amps +) are crying for a regulated driver. With a fet you will probably burn the led to a crispy piece of art. :smiling_imp:
Looks like it could be a good efficiency booster in regulated lights where all you want is an emitter upgrade. Iâd be interested to see djozz test one of these. Iâd be willing to donate to the cause
My sample is in a Olight. I did pull it out and mounted it to a Noctigon and tested it in a C8 with 6 extra 7135âs. It worked very well, did have a little tint shift as you went out in the spill. My BLF Review. I did find an odd artifact in the beam and it was corrected by PflexPro microtexture lens. The artifact was present in the C8 as well, but not as easy to spot. I have since put it back in the Olight, I liked the tint, but I do not know binning on the Olight led.
Just noticed these. This is great you got them on the way!
They sound very interesting - decent output, low voltage. I see it's the same footprint as a XM-L2, so should be a step up for that foot print in terms of output and high amps. They are rated at 5A max, so hoping they can take 8-10A.
At 700 mA, this N4 bin is rated same as a U2, but at 2 A, it's close to a U3 bin. As you up the amps, the lumens output rises compared to a XM-L2. This makes sense because of the lower Vf. If it can take high amps, and then if it can dedome, might be a winner.
Ban - would be great if you can get N5 or P2 bins! I believe the XM-L2 U4's can fail at ~5.2A, so these should be capable of going higher.
Just be aware that this ânew design of C8 style flashlightâ means the revival of the screwed-in brass pill. No copper. Heat transfer will not be as good as for the latest no-pill C8s.
âŠbut you can solder the ledboard to the pill, that is worth something to me. I never noticed any negative effects of brass pills with any 3V led, the XHP50.2 with double the power however may suffer a bit from it.
Hmm⊠I tend to think the pill-less design is primarily interesting for the manufacturer and seller, because itâs cheaper to produce, because you donât have to make a pillâŠ
A tightly screwed in pill has plenty of heat path where the threads are pressed against eachother, squeezed even.
You may be right, I only wanted to point that out. I am unhappy to see âcopperâ everywhere these days when it is just brass with 1/3 the heat conductivity (similar to alu) but three times the weight. Manufacturers are playing Sales Bullsh*t Bingo big time today.
For a powerhouse like this a brass pill is just a bad design concept. P60 times are over. Threads as heat transfer paths may work for a short runtime but there are much better ways to design a powerful light. It is a pity that some suppliers do not have the experience or (even worse) have other priorities.
I suppose it is just the opposite. Making flashlight bodies and pills from tubes is very efficient. Making a pill-less head will need a pre-forged starter piece or a solid block with 80% material machined away.
However brass pills to me seem to be a waste of money for everybody.
Yeah. Google Translate suggests that the Chinese language doesnât make a clear distinction between
copper
é
TĂłng
and copper alloys (brasses, various)
é»é
huĂĄng tĂłng
One hanady thing about pills â being able to make up several of them with various emitters and drivers, and swap them in and out of a single host.
That works if theyâll sell you extra pills.
you should warn your customers that this LED has the anode as well on the thermal pad
now as its mounted on a DTP star this is very unlucky for flashlights
if the star is not mounted electrically insulated to the lights body, you get a direct short whitch is not healthy
