KD (kaidomain): Deals and new products thread
Hello everyone,
I have an order made on the KD kaidomain since 31/10/2018 and it has not been sent. I do not know where the problem is, but 3 weeks are too much for sending the order.
A week ago I wrote a message in the section “Contact us”, but I still have no answer.
Every suggestion is welcomed. :slight_smile:
Thanks
Oooh! triple amber “P6” — ya got me there.
Hi
Yes, it is worked.
Please let me know if you get any problem.
Thank you
Ban
Hi allegreto
You can PM me your order number.
I will help to follow it.
Thank you
Ban
Is anyone familiar with the “CDM P2500”circuit board?
http://kaidomain.com/Flashlight-DIY-and-Tools/led-drop-in/KDLITKER-P6-TRI-Triple-Cree-XP-E2-Amber-590nm-800-Lumens-3V-9V-5-Mode-P60-Drop-in
Just noticed this
Hi Ban
can you please restock 16mm clear silicon tailcap.
i need atleast 10 of them
Nick
Hey ban what size screws are supposed to fit your triple boards?
Hi
We had made a new Triple PCB in recent (20mm x 1.5mm)
New KDLITKER Triple 3TP-20 DTP Copper MCPCB for Cree XP Series / Nichia 219 Series / 3535 LEDs ( 2 pcs )
If you don’t mind, let me give you a rough measurement on the screw hole.
Center hole: 3.6mm
3-side hole (for lens leg): 2.3mm
2-side hole: 1.6mm
(If you are not understand, i can give you some measurement with the item. :wink: )
Thank you
Ban
Hey Ban can you get these HGJ switch PCB’s in the 20/21mm size with out the spring or the switch?
http://kaidomain.com/Flashlight-DIY-and-Tools/switches/S023940-DIY-LED-Flashlight-Reverse-Clicky-Switch-20mm-x-21mm-for-LED-Flashlight
Just fyi, about every P60 pill I bought from several different sources all had the infamous curved shelf. Over the years I just got used to hammering/tapping them out flat - it was well known here on BLF a few years back and we all were flattening them out, just became part of the assembly procedure. I use a flat surface, like the end of a SS ruler to check my work before/after flattening. Can't recall, but I probably used a larger flat end punch, couple light taps on it.
Would still like to hear what BanL may or may not have heard from his sources - it still is poor quality/QC and sure would be nice to get corrected.
It would be good if the feedback reaches the manufacturer.
They could add the fixup steps we’ve gotten used to doing — putting a proper flatended round rod on each shelf and hitting it with a hammer while the shelf sits on a flat anvil, and checking with a straightedge — amd it would probably not add much to their manufacturing cost while greatly improving their reviews from us end users.
Heck, they could even lap the shelf to remove the drilling grooves to make the heat sink contact work. That’d cost more, but be well worth it for customers.
Hey, design and QC/QA done by BLFers is slowly propagating to China. It’s progress.
are order histories still being periodically imported for those that register with the same email address as used with the old system?
I don’t think my order history was ever imported either. I got orders that go back probably 8 years or more with KD.
This is for BanL to know: close to a year ago I made an order through Old Kaidomain, the shipment contained batteries and it never left china because of improper shipping method. As things are know the only inexpensive and legally valid methods to ship batteries are China Post's ground shipping and TNT-PostNL for batteries.
BanL, I would suggest for you to add the above shipping options to Kaidomain (or at least TNT-PostNL for batteries when mandatory).
Cheers ^:)
Ohhh, just seen now you can view your archive order history k, cool!
I’ll admit, I’ve spent at least $300 with Kadiomain in the past month. I might be a flasaholic.
So I signed up with my old email address and my orders are not there. I don’t believe it is a problem but it would’ve been nice to see them.
My orders are there. No problems.
I have had the same issue since 15/11/2018 and first email I was told that my item had been sent DHL (as requested and paid for in my order, paypal express payment) emailed 22/11 for tracking and got a reply that the boards were in production till the 23/11 and that the transport was too expensive for them to send that method ( I made suggestions for other shipping options) but since then no dispatch of the item and/or further communication, emailed again - no reply. Pmed Ban - No reply. Emailed today again, so will see if anybody replies.
EDIT: SORTED :slight_smile:
