acebeam X60 charging system
Hi all!
Bella from acebeam asked me if i would "field test" their improved battery carrier - i said yes!
Some days later a box arrived with a X60 taken from the warehouse (with the "old" carrier installed) and 2 additional "improved" carriers. also in the box were 6 acebeam 2600mAh cells.
Using 6 identical cells is very important!
(The light was not free, but the new carriers and the batteries were...)
The screws on the carriers are glued and i did not open it (but maybe i will ;)) to check the difference between both versions...
but beside the words "TD4055" and "LTC4054" written with a sharpie i cant see any difference.
Bella told me that the new charging ICs have several advantages:
~ gives wrong polarity protection
~ delivers 500mA to each battery
~ intelligent CC and CV charging
~ charging accuarcy is 4.2V±1%
~ ensures protection against over-charging
~ if it detects shorts,defect or low discharged batteries it stops charging
nothing new - but the real difference is that the 4054 seems to be made with higher quality than the 4055 - which results in a much more accurate charging.
and thats what we are looking for!
How i tested:
  • the charger used was the EU-version (230V); the USB-plug was not used
  • i marked the cells 1-6 and also the carriers bays (#1-3 upper row, #4-6 lower row; facing the head)
  • before each charging run the cells where cyceled 1 up - cell in bay #6 went in bay #1
  • all values are taken with the same DMM
  • temperatures seemed always to be in normal range - but no big variance of single cells
The test as “a story”:
The cells arrived all carged to 3,65 Volts and had an isolating sticker on both poles. Since the 4055 carrier was already in the X60, i started with that one to see what happens to delivered units….
After around 5 hours the charging indicator went from red to green - i pulled the cells and meassured between 4,17 and 4,22V. After 1 hour letting rest the cells outside the readings were the same.
I put the cells back in the light and took it outside the first time (impressive btw!) - some playing later i meassured 4,02 - 4,07V (each cell dropped 0,15V). then i left it on for some time at different brightness levels and next meassurement gave me 3,89V to 3,93V ( again - each cell lost nearly the same amount of voltage).
Then i used the new 4054 carrier to charge and the cells leveled to 4,19V - 4,21V when the light turned green - another charging for 6 hours did not really make a difference (some cells went up 0,01V, some 0,01V down)
To see how good the balancing works i used a BT-C3100 to discharge 3 cells to ~3,45V and 3 cells to ~3,68V - a difference of 0,25V…
Back in the 4054 the cells where charged to 4,19 - 4,21V again
Then i used a fan to cool the head and let it run very hot until i saw that the output was noticeable lower - the cells dropped to 3,77 - 3,78V rotating them and recharging resulted in 4,20 - 4,21V
Then i “regulary” used it down to 3,76 - 3,78V
Now i used the 4055 carrier again to see what happens to this well balanced cells - result: 4,17 - 4,22V
Using them down to 3,70 - 3,73 shows the same behaviour again: the cells drop the same voltage…
Now the second 4054 carrier had to show if it was as good as the first one: 4,19 - 4,20V
a hot run later the cells came out with 3,64V each and have been recharged to 4,19 - 4,20V.
i let the light on on a medium level (cold basement) and when i meassured the where down to 3,6 - 3,62V
last charge resulted in 4,20 - 4,21V
I think the new charging chips do a pretty good job!
numbers!
#1
#2
#3
#4
#5
#6
at delivery
3,65
3,65
3,65
3,65
3,65
3,65
charge with 4055 run #1
4,21
4,19
4,19
4,22
4,20
4,17
rested 1h
4,21
4,19
4,19
4,22
4,20
4,17
used
4,06
4,04
4,05
4,07
4,05
4,02
used more
3,92
3,90
3,91
3,93
3,90
3,89
charge with 4054 #1
4,19
4,21
4,19
4,21
4,19
4,19
charged 6 more hours
4,19
4,21
4,20
4,20
4,20
4,19
discharge 2x3
3,45
3,45
3,44
3,69
3,68
3,68
charge with 4054 #1
4,19
4,21
4,20
4,20
4,20
4,20
heavy use
3,77
3,78
3,77
3,78
3,78
3,78
charge with 4054 #1
4,20
4,20
4,20
4,20
4,21
4,20
use
3,76
3,77
3,77
3,77
3,77
3,78
charge with 4055 run #2
4,20
4,22
4,17
4,18
4,20
4,20
use
3,72
3,73
3,70
3,70
3,72
3,72
charge with 4054 #2
4,19
4,19
4,19
4,19
4,19
4,20
used heavy
3,64
3,64
3,64
3,64
3,64
3,64
charge with 4054 #2
4,20
4,20
4,20
4,20
4,20
4,19
use
3,61
3,62
3,60
3,60
3,61
3,62
charge with 4054 #2
4,20
4,20
4,20
4,21
4,20
4,20
in the graph i tried to show how close the voltages of the 6 cells are...
i hope you can follow my thoughts…
all numbers can also be reviewed under this link:
https://docs.google.com/spreadsheets/d/1NqEK5P26aju8lBWRXHXR2RG71KYsdGJM2e4A7BUGf78/edit?usp=sharing
what i plan to do (as my time allows):
i will charge (not use!) some unmatched cells to see if the paralell charging works fine with that setup too
maybe a modify the carrier to be able to measssure the voltages of each cell while in discharge
i will update the google table from time to time to monitor the long term quality
i ordered a infrared thermometer to get more info for my reviews and tests
if i missed a test or measurement you are interested in i try to do it - just tell me!
no comments on this? anyone?
I have commented on the other thread. Linear Technology is an American company, quite a huge one, that produces the LCT4054 chip. The other chips called TP4054 are Chinese clones, which are easily confused with the LTC4054, the people who cloned the chip wanted to use a similar name.
What is the TD4055 supposed to be I do not know, I know there is a TP4055 Chinese charging IC which was taken to sound like LTC4055, yes another charging IC from Linear Technology .
Maybe a hand writing error that made the P look like D, as the TP4045 and TP4055 are common parts used in China.
I have no reason to doubt this review’s results, but, as they say, “the truth of the pudding is in the eating”. My replacement X40’a carrier in on the way, in a few days I will be able to know the results of ‘my’ new carrier.
As long as my new carrier’s charge and discharge voltage results are with-in the manufacturer’s and considered with-in safe tolerances after repeated cycles, I won’t really mind what parts were used, regardless of brand and price.
