ULTRON AA
an advanced AA/14500 boost driver
Hello, let me introduce my first custom driver. It is a boost driver for AA/14500 lights. I have also written a firmware for it. It has three lighting modes and 3 hidden strobes. You can reprogram each light mode by ramping.
Features:
Standard modes use fast, inaudible PWM. The lowest mode doesn't use PWM though, it is a linear moonlight and you can change it by replacing one resistor on the board (this way you can achieve the lowest low you can imagine and reduce the consumption as much as possible).
It uses the off-time memory, this means that you can change the mode anytime with just a single tap. The light will always start on the first mode when you take it off the shelf (the mode resets after the driver is ~5s off).
You can access the strobe group by three fast taps (half clicks). You can do the same to return back to the standard levels.
Strobe patterns are:
Fast strobe, 2s double flash beacon, SOS
You can access the ramp program group by six fast taps. There are three modes with ramping and each of them programs corresponding standard level (ie. first ramp is used for programming of the first std. mode)
Ramp always begins on the lowest (linear moonlight) level and then goes up to the highest level. You can confirm the level you want by a single tap, this will save the level and jump to the next mode ramping. The ramping repeats until you confirm some level. The end of programming is confirmed by a single flash.
Mode spacing diagram:
Other:
It uses common ATTiny13 mcu and you can use programming clip to re-flash the firmware.
It uses commonly used output pins so it should be compatible with most custom firmware (some small changes might be needed - ie. you might have to disable low voltage detection).
Make sure you use PROTECTED 14500 with this driver as it will over-discharge unprotected ones.
Dimensions:
The first batch diameter will be 15mm. Larger diameters will be available later.
Flashlight compatibility:
Sipik SK68, Sipik SK58, Trustfire F20, Akoray, Skyray S-A1, Trustfire R5-A3, C3, Ultrafire A10... and many many others
Photos, video and more details will added later.
There will be a sales thread next month.
