<span class=“language english the in myself express to way correct the me suggest and phrase” “strange a wrote i where me point wanna you if corrections and suggestions accept I me. with compliant be please so error, grammar of lot a making surely am i english, in write to good so not am i”>
First impressions:
Shipped from: buyincoins http://www.buyincoins.com/item/43808.html
…….also found on fasttech site:
- http://www.fasttech.com/products/1601/10009846/1864905-windfire-j18-q5-cree-1-cree-xp-e-q5-3-mode-350lm
- http://www.fasttech.com/products/1601/10007767/1675208-1-cree-xp-e-q5-3-mode-350lm-zoom-cool-white-white
It’s the classic cheap flashlight with aspherical lense, it’s notmal i did’t expect much from it
I think it’s a good alternative to the sipik and all aspherical lense flaslight that you can find out, why? The zoom is usable with a rotable bezel, so the flashlight lenght will never increase or change.
Modes and estimated lumens:
Switch type: MECHANICAL
There are “ 3 ” modes in the following order:
Hi – low - strobo
My estimated lumens are 150/200
>>LIGHT >>> The angle of refraction:
Weight and dimensions measurements (made myself, not by specs):
This flashlight weighs precisely 116 gr
Height 15,6 cm
Diameter 2,8 cm
Head diameter 3,4 cm
Construction quality:
The host is reasonably well made for a low cost item.
Rotable bezel mechanism is not an high machined piece , but performs the job sufficiently well
Lanyard hole: PRESENT (one)
Threads came NOT GREASED, but this is not a big con, i used my grease.(mine isn’t an high quality one, but you can buy a top notch if you prefer)
Led Tint, reflector and lense:
Led tint is a very cold white….maybe too much.
Lense made of: PLASTIC
Outside beamshot at 25 meters, only at FULL power (same place for all my reviews)
Wall beamshot at 250 centimeters, from lower to higher power (same place for all my reviews)
Ceiling bounce test with LUXmeter:
PROS:
- really cheap
- not bad construction for a low cost flashlight
CONS:
- light output just sufficiently ok for general usage
Final thoughts and why you should buy it:
Why should you buy it? Maybe because it’s a present for friends or a familiar with few pretensions from a flashlight, being accustomed to “supermarket” flashlight !!
Thanks for reading……
….and if you notice some bad written phrases, feel free to correct me suggesting the right way to write it!!
