Decided to use a single 18560 holder and the little USB charging board that HJK tested. I also used the red led voltmeter, it activates at the lowest voltage of 2.5vDC. The parts are attached with black silicone and hold rather well.
I did forget to calibrate the voltmeter before mounting it and it is off about .06 volts. So, I will cut it off and recalibrate it.
I would like to find a better battery holder, this one does not fit button top protected cells well, they are to long.
Matt
