This is just a quick review on the LD30 driver purchased from Banggood on the 30.5.15. This driver looking at pictures from different sources does appear to be slightly different from each other.
The driver would not operate correctly above 2.8 volts so all testing was carried out below this voltage.
Low voltage protection appeared to kick in just below .8 volts with the driver switching off. To get the driver to operate again the voltage had to be raised to around one volt.
There was no mode memory with the driver always starting on low mode regardless of which mode the light was switched off on (makes sense to me).
The led wires for the led were attached to the driver and were large enough being 24AWG for the current output of the driver on high. No contact for the positive on the battery to contact the driver is present so a small spring or button will have to be soldered to the positive pad for the battery to contact. I have noticed and have purchased this driver elsewhere where it has a small pad attached already for the positive on the battery to contact. The driver itself measures 17mm in diameter.
Edit. All testing was carried out on my bench power supply and an XML-2 led on copper MPCB on a suitable heatsink used for the load on the driver. A fan was used to cool the driver and led during testing
LD30 3 Mode Driver Low |
Input Voltage |
Input current |
Led Voltage |
Led Current |
2.8 |
.04 |
2.62 |
.35 |
2.6 |
.04 |
2.55 |
.01 |
2.4 |
.04 |
2.55 |
.01 |
2.2 |
.05 |
2.55 |
.01 |
2 |
.05 |
2.55 |
.01 |
1.8 |
.05 |
2.55 |
.01 |
1.6 |
.05 |
2.55 |
.01 |
1.4 |
.05 |
2.55 |
.01 |
1.2 |
.05 |
2.55 |
.01 |
1 |
.06 |
2.55 |
.01 |
.8 |
.07 |
2.55 |
.01 |
LD30 3 Mode Driver Med |
Input Voltage |
Input current |
Led Voltage |
Led Current |
2.8 |
.14 |
2.7 |
.1 |
2.6 |
.15 |
2.7 |
.1 |
2.4 |
.17 |
2.7 |
.1 |
2.2 |
.18 |
2.7 |
.1 |
2 |
.19 |
2.7 |
.1 |
1.8 |
.2 |
2.7 |
.1 |
1.6 |
.22 |
2.7 |
.1 |
1.4 |
.25 |
2.7 |
.1 |
1.2 |
.29 |
2.7 |
.1 |
1 |
.35 |
2.7 |
.1 |
.8 |
.43 |
2.7 |
.1 |
LD30 3 Mode Driver High |
Input Voltage |
Input current |
Led Voltage |
Led Current |
2.8 |
.7 |
2.97 |
.46 |
2.6 |
.74 |
2.97 |
.46 |
2.4 |
.76 |
2.97 |
.46 |
2.2 |
.85 |
2.97 |
.46 |
2 |
.93 |
2.97 |
.46 |
1.8 |
1.02 |
2.97 |
.46 |
1.6 |
1.15 |
2.97 |
.46 |
1.4 |
1.33 |
2.97 |
.46 |
1.2 |
1.58 |
2.97 |
.46 |
1 |
1.95 |
2.96 |
.45 |
.8 |
1.85 |
2.93 |
.4 |
