This is my first major mod and first ever mod thread, i never intended on making a thread for this light but half way through i decided to take a few pics and make a thread. so here goes…
i decided that the courui would be a good candidate for the PT54 with its parallel battery configuration which matches the PT54s low Vf and high current.
i started by machining off the anodizing and re tapping the threads deeper to accommodate longer cap head screws as one of the screws was threaded from when i received the light
i also bypassed the springs and added a omten switch to lock the light out.
i had to run this light as a POSITIVE ground as the PT54 has a positive earth, so i just soilderd some button tops on the neg side of the batteries so they would make contact with what was the old positive section on the contact board. This seamed the easiest way of achieving this i guess. just hope i dont forget one day and put the cells in the wrong way!! i might get magic smoke…
i then proceeded to make the best possible heat sink as i was going to run this thing at 9A, i made a solid copper slug for it in the lathe.
its a light press fit, i think it worked out well. I glued the led to the pill using arctic silver, i also enlarged the hole for the emitter in the reflector before i started to take pictures, so this way the emitter would self center itself in the reflector. i also kept the whole star (if you will) that the emitter is mounted to as it gave me plenty of clearance to sit the reflector right down with no risk of shorting out.
I decided i would use the new LD-M2 driver as it was perfect for this emitter, i couldn’t be happier with how it runs with this led. I also glued this to the back of the pill using arctic silver epoxy and passed the negative wire through to the emitter.
all screwed together and well for my first major mod, i guess it turned out ok. i took a few beam shots from my front door as it was late when i finished it. it goes much further than this but i ran out of objects to shine at, pretty good for a red emitter i think…
