http://www.ebay.com/itm/280724961881?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Today i recieved my 2 samples of this thingy and had been positively impressed. For what i paid (just a bit under 20usd for 2) it is a great value.
The only grief is the pressed tail switch department and the pressed driver but fortunately is a good one. Otherwise very neat for the price. Finish is decent and i immediately removed the spring at the driver (poorly soldered and barehandedly snapped off - i liked that) with the spring a xtar 18700 2600 had an exteremly tight fit, beyond comfort levels. Without just perfect.
Current draw:
A:
hi - 0,98A
mid - 240mA
B:
hi - 0,95A
mid - 231mA
Pretty decent so i leave them as is. Smooth push pull operation, non overly stiff clip nad plastic lens. Disassembly is very easy. Heat transfer can be improved by messing with tin foil but a bit tricky to do it right. Require some steady hand an patience. Not very modding friendly since the driver aint soldered but at such price there is hardly anything better atm. Looks nice and it is not much bigger than the sipik AA sibling.
Not scratched and decently anodized. I had a feel it would came painted or other half assed job. Internals are from aluminum and some cheap metal lookalike for the bezel. A steel one would top it nicely. 4 lines of taicap threads are barely enough but work fine and not flimsy at all. Screws on like a solarforce would. Smooth as butter:)
It does have a relatively narrow flood and an usual emitter shaped hotspot when zoomed in. Pretty standard but i noticed both had the least amount of artifacts present in all such designs. That's another good point. The strobe is fast and annoying, and as usual i wish it was not there at all.
What more to say? I can reccomend it if one likes such lights. It is rather big for EDC but can be done. Afterall it has a nice clip very similar to the sipik sibling.
If they managed to do a decent tailcap and a better brass made pill this could be the best zoomie in the market (budget wise). Despite the few drawbacks i like it more than my ex romisen RC-C8 which had a bit better build quality of internals.
One o-ring at tailcap. If fiddled with a bit one can make it easily waterproof but not submergeable. The zoom action kill the watertightness and as such it cannot be improved further, no other easy points of water entry however.
That's it.
Reccomended without second toughts. Pics later if i find a camera.
