I like this cells!
Added spring bypasses, 9 amperes now, about 3300 lumens, with modded banggood BLF X6 driver. More than my new Convoy L6 with N2 bin.
Btw, modding the UF13 was a pain with my poor equipment …
In my Shadow JM 30 with XHP 70 direct drive
they work and fit well.
Regards Xandre
got my first 2 pairs
each in a 2x26650 box
wrapped in foam together
in black plastic bag
first pair sits in the OPUS BT-C3100 @ 700mA for charge test
My first charges I did with 700 mA. Now I charge with 1000 mA. Is it too much?
I got two readily available lights where I use 26350s and a third is on its way:
Jaxman Z1 XHP50
Shadow JM35 (2cell)
BTU PK26 (soon hopefully)
Ordered one pair of 26350’s on july 7th 2016.
The batteries arrived yesterday, on july 27th 2016.
And went straight from the hands of the mailman into the BT-C3100.
A charge-refresh cycle on 500 mA resulted in 2,256 mAh and 2,210 mAh.
are these cells sufficient for the BTU PK26? I think they are 4A drain. Don’t they need to be more?
Received my two pair today. One pair on the lii-500 for testing and one pair in my spring bypassed Convoy L5. The Liitokala 26650s work fine but a pair of 26350s were too tight in a single tube. I remedied that by cutting a piece of the ground from some 12/3 electrical wire and bending a circle then inserting it in the head behind the pill. The tube screws in enough for good contact with the o-ring and reduced pressure on the cells to an acceptable level. Working fine in 2s. These cells create some nice options for 26650 powered lights.
Mine arrived a couple of days ago, well packaged and with a voltage of between 3.86V and 3.89V over eight cells is not bad!
Yet to charge them and put them to use.
Thank you M4D M4X!!
From the L6 ‘big’ thread:
are there lights out there that use these 26350 cells? I mean besides the BTU PK26. Example?
Why the driver side? Why not the tail cap side? Add a small button to the switch pcb?Do you think it could be possible to gain clearance by putting a smaller washer or shim on the switch and maybe cutting the boot nub down?
Results for my 2 pair:
Cell1 ir 39 capacity 2233 termination 4.22v
Cell2 ir 39 capacity 2248 termination 4.21v
Cell 3 ir 40 capacity 2127 termination 4.22v
Cell 4 ir 33 capacity 2249 termination 4.21v
Cell 3 is a bit lower but I had one of the lii 26650s give a lower reading on the first test and on the second it was very close to the others.
On the driver side the positive contact of battery protrudes a little. I can put a brass button there just high enough to the battery clear the components on drivers battery side. In the tailcap the spring can be compressed into the switch board retaining ring But I think It can be smaller spring on that side too.
Hi fellows!
A DERP! ago I stumbled upon this while browsing stuff at FastTech: INR 26350 3.7V 2000mAh Rechargeable Li-ion Battery (2-Pack)
Explains for itself, doesn't it?
Enjoy. :-)
Cheers ^:)
Yeah tease us more you devils Ft offers me a single shipping option via emirates post that costs 92 $! ….Emirates posts…BG doenst ship to me at all…
Damn Liion regilations…
