Active cooling means it uses a built in fan. So it does make a big difference. If the DX80 had active cooling, it would probably be able to run continuously at 12k to 14k lumen instead of 7k lumen. It may also double the time it runs at 32k lumen.
Not everyone needs this extra performance, but for those who do, it’s a big deal.
I definitely rate Astrolux as a higher quality brand than Imalent. Of course, opinions vary.
I don’t think being repairable makes it a high end light, just a more desirable light. It’s a small, but important distinction.
I tend to gravitate to companies that sell parts (Eagle Eye and Convoy) or lights that I know I can get a replacement driver for (thanks to MTN Elec and Lexel).
It’s always a bit risky getting a light like the DX80 should you have an issue. I’d much rather pay $10-$20 for a new driver than $110-$120 for a new head.
It looks like Lexel might be making a new driver for the MF03 when it comes out. It’s a combo FET/boost design. That’s pretty cool. It makes me less afraid to spend my money on it. Plus you get the cool NarsilM ramping UI which I like.
If Imalent offered replacement drivers for the DX80 I would consider buying one (same for DT70), but they don’t. The risk of getting a defective light just makes me want to bypass Imalent totally.
I know, I was trying to make the point that it's very decent of manufacturers to consider those of us who can tinker with them.
Of course I know what you mean with Imalent, but if you can look past the risks, their DX80 is such a fun light, it's hard to ignore, but yes, it's a huge letdown when you get a defective one and have to pay a high price for it. Luckily Gearbest was very decent to me and gave me a very good credit when they really didn't have to. I was thinking they won't come through, but in the end they were 5 star all the way and I am very thankful to them.
To give these nice people here and their information about the DX80 something back, I just registered here and have images of the disassembly destruction of the battery part.
The DX80 stopped charging and after contacting the support, they send me a new one. TOP!
Later I tried to find out, why the first one stopped charging, to avoid mishandling the new one.
You all know how the battery back looks like, therefore I have no picture of an intact one here :)
First I removed the "do not disassembly" plastic cap, which was the easy part.
After that I tried to use force everywhere, but nothing more came out, besides the battery pack itself moved around a bit, just did not came out.
After some more brute force I got it open, here are the pictures and some notes, which may be help someone else not to destroy it too much in case of service needs :)
Besides my dremel cut, this what it looks like to remove the plastic cap:
I guess, if use some tools to turn flat surfaces, the black aluminum ring should be able to be removed by simple unscrewing it. Since I had no luck , I cut the ring and was able to lift it out with a little force.
That's it. The battery pack then came out.
This is how the electronics looks like. I got some corrosion and blown diodes and stuff there :(
These are the batteries. Maybe I can reuse them for something else :)
Wow! So Imalent sent you another new battery pack or the whole light?
Can you ask them whether the new battery pack has new design that prevent this burn?
With 2 little holes in the aluminium cap you could have opened it. Its a pity that you have destroyed it.
If you would have asked, I had suggested it to you.
Can you make a better picture of the battery-balancing board?
Nice pics codenox, thanks! I was reading elsewhere that someone said they can actually see the driver through the fins and when they dropped the dx80 for a very short time in water, it died. From what I understand so far, whatever Imalent may put in the specs, I think this light can not be anywhere near water.
Man I recently purchased this flashlight last week, and after reading this forum has me a little worried so many in just this small community have had trouble with the light. I am going to be using it in a little cave run today so it should several hours straight we will see how it hold ups. I will not be pushing for HIGH levels of light, i will most likely stay at 1500 which is more than enough.
Well using the light went good, got home checked batteries which were at 15.8v and guess what…… it wont charge…… GRRRRRR
Plug in the power adapter the red light comes on it, plug it into the light and the screen flickers the battery symbol with 5 bars and than goes right back off. I have tried removing head and letting it sit and than trying again same difference. While plugged in the light will not turn on which I have read it shouldn’t. I am at a lost here is their anything I am missing here?
Also didn’t notice this when I received it but mine didn’t come with a holster, I made the comment walking it would have been nice to have one to put on the outside of my backpack my wife said the picture online showed it came with one and sure enough we double checked the box and no holster
Have you measured voltage with a DMM to confirm 15.8v is a correct reading? It does come with a holster for sure, so they must have forgot to include one with yours.
