Thanks for your answer!
I was hoping a more simple solution ,maybe buying a few replacements from aliexpress.
Nope ,no internet provider ,the username it’s from an satellite chanel package https://en.kingofsat.net/pack-viasat.php .
Best Regards!
That ‘O’ ring is Buna Nitrile and can be spliced with Cyano-Acrylic (CA) glue. The CA melts into the neoprene and can be as good as the original – not used as elastic but a seal. When gluing be quick and precise, there isn’t any time to move the ends into place. Any excess I remove with a very sharp X-acto knife, sometimes I use a razor blade as more precise.
There is an American supplier of all sorts of ‘O’ rings The O Ring Store – if shipping is reasonable.
Since im not big fan off Anduril ’s smooth ramping and linear stepping mode, compiled new UI similar to Olight Baton and more balanced for headlamp output. Now testing with buck-boost TPS63020 driver…
For perfection, as you can notice, lowest mode can be dimmer and it have some lite PWM visible on camera only. But i have long winter ahead for improvements. ;))
I’m a big fan of the Anduril modes. Olight UI can be pretty good, but only if the mode spacing is perfect. What I like about Anduril is you can pick your # of modes yourself, and where they start and end, and imo the spacing always ends up perfect.
Yes, its all about spacing. At least in Anduril 1 stepped mode spacing is linear. It dividing steps for ramp length equally. But for headlamp (and not only) is more important to have modes in low range … like 4 modes from 0.5ma to 500ma. and hi at 1000ma. And of course separated turbo like 2-3amps for short time or as long as possible.
The time should be your time zone assuming you set it up in your user profile.
You won’t get new notifications after an edit. If you click the subscriptions button (on the left) you will see all your subscribed threads and it will show if there are any new posts. New includes edits. Clicking on the number should take you to the new ones, but if it’s an edit it might not. You’d have to scroll through the dates to find the new one.
