Nice comparison. It shows, that we still lack cold/extra cold white good CRI emitters (6500K to 12000K), because that is a difficult story.
I already think about ordering a quad of E21A 6500K, because Maukka measured it around 7100K, and that is the only one really cold white emitter with high CRI.
Two more headlamps for emitter swapping are already on their way to me.
I think this would be interesting if shot with white balance matching the emitter tint. I think it would bring out the visible advantage of the CRI of each. Our eyes tend to adjust white balance when looking at things and we do not see the solid orange of the warmer tint emitters.
great pics!
I would like to see same with WB @ 4000k, 3000k, and 2000k
agree
looking at a 2-3-4000k emitter, with White Balance set to 5600k is not my real world application of night time flashlight use. Also, when camping with no ambient light, I find 3000k very pleasant, while 5000k+ is overly blue. Same waking up in the dark, my brain finds 5000k+ too Cool.
All depends on the WB of my brain at the time. Example, my house lighting is 3000k incandescent. After 30 minutes in that environment, my brain sees 5600k as WAY too blue.
otoh, during the day, when my brain is adapted to Cool White Sunlight, even 4000k looks too orange.
So, my choice of CCT changes based on what White Balance my brain is adapted to.
whether a light looks Cool or Warm, depends on the White Balance of the operators brain at the time.
IF the operators brain is adapted to sunlight, then a CW light will seem white, and a NW light will seem warmer (yellowish).
otoh, IF the operators brain is adapted to darkness (takes 30 minutes in the dark), then the CW will seem blueish and the NW will not seem yellowish.
the following photos are from iPhone 8 with Automatic white balance. Notice how their color changes based on what they are being compared to. Remember the camera is changing its white balance in every shot. IF the photos were taken with a camera with a Manual white balance setting, then all the colors would stay the same. (and what those colors would be, would change based on which white balance Color Temperature was being used)
A light will look blueish if it is cooler than the white balance of the brain at that time. And a light will look yellowish if it is at a lower CCT than the brain is adapted to at that time.
If Im acclimated to 3000k Incandescent, then ± 1000k is pleasing, ie, 4000k or 2000k
If otoh, Im acclimated to 5000k White Balance, then ± 1000k is still pleasing, ie, 6000k or 4000k
note that in WB of both 3000 and 5000k, that the 4000k is within +–1000k
I refilled my ink cartridge. The cost for large black ink is ~USD7/refill and the color (-RGB-RYB) ~USD10. And I printed on used 80gr/m^2 A4/4 paper (105mm x 150mm). There is a famous ink refill center here called VENETA System. It sells refurbished/recycle ink cartridge and also ink refilling using bio-degradable inks.
This is an interesting experiment. I’d like to see if the “real” color wheel works better for this kind of ‘discovery’ experiment, as has been mentioned. Especially interested in that because refill inks, in my experience, are usually lower quality than OEM. So, the difference might be even bigger than if Clemence had used OEM inks, which are already not ideal for this.
budget living has been infiltrated my life.
FYI, the refill ink quality is almost as good as the OEM at 1/3 the price. I don’t expect significant differences by trying OEM ink cartridges. Better start browsing for real color wheel.
Yeah, I wasn’t trying to suggest you should switch back. For most non-color-critical printing, it is definitely worth refilling for the price difference. I was just saying for something like this, I’d expect a “real” color wheel to be a huge upgrade.
Yup, most of my applications are just printing receipts, invoices, and some wiring diagrams.
Do you know any good quality color wheel manufacturer at reasonable price?
If his printer has a 6-colour ink system, it might print out colours better than the standard CMYK (3-colour + black) system. Otherwise, it’s probably missing out on the saturated hues, especially red, green, and blue. That could lead to more difficulty in distinguishing colours than would be the case with a proper colour wheel.
