I received my FWAA sst20 4000k today, really happy with the light. The build quality and tail switch feel much better than my first batch FW3A. I can’t believe how small it is too! I’d definitely be in for a titanium or stainless steel FWAA if Lumintop wants to go that direction.
In the ramp mode or candle mode, it's possible to make the light turn
itself off after a while.
To activate the timer, go to the brightness you want and then use a 5H
action. Keep holding the button, and the light should blink once per
second. Each blink adds 5 minutes to the timer.
In ramp mode, it slowly dims until it's at the lowest level, then shuts
off. In candle mode, it stays at the same brightness until the final
minute, at which point it dims and dies out.
The user can change the brightness while the timer is active. If this
happens during the final few minutes, it also "bumps" the timer up to a
minimum of 3 minutes. So if it's getting really dim and you need a
little more time, you could do a 5H to add 5 minutes, or simply ramp up
to the desired brightness.
yep, the DQG Slim AA is indeed a bit longer. I have measured mine at 76,6 mm, 2,1 mm longer than the FWAA. The DQG Tiny AA II (which is of course a twisty) is 68 mm long, 6,5 mm shorter than the FWAA.
I can’t believe it’s that much smaller than the reylight Pineapple… dammit, maybe I will have to order one of these. But I’ll probably just wait for brass to come out, if it ever does. Because it really should - freeme
Arrived today. This is my second Lumintop, and this one is even more impressive with the Anduril 2 driver. Soooo small. I haven’t got my head around the interface yet, but I will.
it sure does! I’ll keep mine in simple UI with a greatly reduced top ramp - no turbo. I can always put it back in advanced UI if I want to show off for 5 seconds.
Anyone know how the tints compare for the Nichia 219C 3000K and 4000K versions?
Any projection of CRI on these two and for the SST-20 4000K?
Apologies in advance if this was covered earlier in this thread.
