Looking about at specs and current offerings, it got me wondering on the benefits and negatives of a triple XM-L2 light vs a single MT-G2 light, in same something similar physical size and power source.
For example there is the FourSevens MMU-X3 with it’s triple XM-L2 and single 26650.
It claims 1600 lumens max output.
And then there is the new Fenix PD40 that is almost identical size the FourSevens and also runs a single 26650.
It too manages 1600 lumens. Fenix quote the lux at 10,000cd while FourSevens don’t quote this, you’d assume a 3 x XM-L2 won’t be all that throwy either.
I know in this instance the Fenix is likely nicer tint/CRI. But XM-L2’s are available in better tints than CW.
Are the completely different lights that get very similar results?
How about moving up to larger power sources. We all know the MT-G2 really likes more volts and 2x Li-ion to really perform or more.
A bigger torch = bigger reflector and more throw too.
But wait more volts with three XM-L2’s also means easier to drive them harder. And while each reflector would be smaller, a larger torch means they would still be bigger than before and the XM-L2 being a smaller LED, is throw vs flood going to be massively different?
Looking at the spec sheets:
http://flashlightwiki.com/Cree#XM-L2
3 amps should net between 1044 and 1268 lumens for an XM-L2.
So if you had three of them at 3 amps. That’s 3132 - 3804 lumens.
What sort of lumens would the MT-G2 be capable of making on a similar setup? Guessing it would be more than the XM-L2’s, but by how much?
