glad the teflon spray lube is working to make the light smoother to twist
I also find some of my twisties stick when first twisted, its part of what moved me to clickies instead of twisties
> Maybe very thick … grease
nyogel 767a is very dense and sticky, you might like it in the threads, to fill gaps and resist rotation
I dont think it needs to be conductive, as long as the end of the body tube, and the contact ring on the pill, are kept wiped clean, no excess lube.
What I use in the threads can be thicker than what I use on the O ring itself.
I would still use a thin lube on the O ring, such as Nyogel 760, or Nano Oil.
I get Nyogel from oveready.com and I get Nano Oil from darksucks.
I have two lubes with teflon, I do not like them. They tend to stick and make it difficult to turn the threads. It seems they are designed to coat metal surfaces, rather than lubricate them…
I have Krytox 205, highly NOT recommended. It dries to a white powder, and sticks terribly to O rings, making it feel like the light will tear the Oring when turning the threads… bad bad bad,
I also have TefGel that I find much too sticky, both in threads and on O rings, so also not recommended…
one of the very best lubes I have found is the darksucks Munky Spunk. It is a thin grease, works equally well on both threads and O rings.
