As predicted this light will likely get hot very quickly and have a short run time on maximum.
the custom triple MT-G2 light i have here still gets quite warm even with active fan-cooling built in after a few minutes on highest mode. (15 + amps from eight 25R 18650s.)
its not a “stock” light, but the custom one built by OldLumens.
It uses eight Samsung 20R High-drain cells, (4P2S)a custom driver, active fan cooling, and a modified head formerly from a SP03.
I further did some more mods to it, adding more 7135s, pushing the tail-cap-amps to over 15 amps on high, here:
That is the only one i could do a comparison directly too the X60M is the OL triple-MTG2.
The other “big” lights i have my collection are a SR90, TN31, Cyclops 55W HID, 11-Amp SRK Kung, X40 NW, etc.
would not match the X60M for flood output and maximum Lumens,
So will this light actually pull over 18A from the 6 cells? 3 MT-G2 will have to be getting over 6A each to produce that kind of output, and it will be floody in those small reflectors without a doubt. Might be a bit scary on the cells some people might try to use.
This is definitely a light that will need to have it’s warnings paid attention to.
I have 10 MT-G2 lights, heat is probably the major concern and in most cases with this emitter it’s not a question of 3 minutes, or 2 even. At any rate, the cells will be making a vacuum sound as they are drained, trying their dead best to create a new black hole in the universe.
Ok I’m confused. I have built a bunch of 2x18650 MT-G2 lights and many of them up to 3,000 lumens. So why exactly wouldn’t 6x18650 run 3 MT-G2’s? As long as the driver is set up as a split channel driver with one channel to each emitter it should work just fine.
Now heat on the other hand, I think we all know what three MT-G2’s is going to do when it comes to that.
There are no issues as long as normal high current cells that can handle 5-10A is used.
All the 6 cells are most likely in series. Peak amp draw is probably around 5,5-8A depending on battery voltage when its at full output.
I would just look at the light as a sub 4000 lumen light with a good turbo mode. For a 3800 (?) lumen light efficiency is probably good. Range, not so, but there are other lights that does range.
Sad to say but someone probably will put them in this light at some point in time. That would be a problem.
I actually just bought a bunch of MT-G2’s the new ones, to make a few 3xMT-G2’s. I’m going with the J-19 for a host like I did in the past only this time I’ll use a linear driver from Cereal Killer and wire them in parallel. I’ll need to use a bunch of thin wire to add enough resistance, but I do know that they will not FRY because I did wire a 3x direct drive from three batteries in series before.
Like you said, turbo mode on high and good efficiency on lower modes. Three 32650’s should be pretty good run-times too. Plus the J-19 is a massive light. It’s actually heavier than a BTU Shocker. I’ll still be adding some copper under the hood though.
I could just buy one of these but I have the feeling I can build three of the J-19 ones for what this bad boy is going to cost. Plus for me it’s all about the modding.
