Hello.
I have always loved the Eveready Dolphin, but I’ve never actually owned one. Growing up in Australia if you had a dolphin you were pretty cool. I think my Dad had an early model years ago, but it’s long since gone.
I have quite a decent collection of high powered LED torches now, but still no dolphin.
Anyway I was watching a random video on youtube and got an idea… (this is the video: http://www.youtube.com/watch?v=CIBIqaeiE2M)
Essentially I thought I would like to build a 100W torch like in the video, but I want it to be relatively compact and portable. Clearly the one in the video is not very convenient.
The I remembered the Dolphin! I figured it would make a perfect case for my 100W LED torch.
Here is a list with links to all the parts I have purchased so far with their cost:
100W warm LED ($8.59AUD): http://www.ebay.com.au/itm/281207784685?ssPageName=STRK:MEWNX:IT&\_trksid=p3984.m1497.l2649
12v-35v Voltage stepper ($7.99AUD): http://www.ebay.com.au/itm/350944899876?ssPageName=STRK:MEWNX:IT&\_trksid=p3984.m1497.l2649
12V 6800mah lithium rechargable battery ($10.70AUD): http://www.ebay.com.au/itm/111196510869?ssPageName=STRK:MEWNX:IT&\_trksid=p3984.m1497.l2649
2.5CM 12v .12amp cooling fan ($5.72 AUD): http://www.ebay.com.au/itm/390760269887?ssPageName=STRK:MEWNX:IT&\_trksid=p3984.m1497.l2649
Reflector and Lens for 100W LED (not sure if I’ll use this) ($3.66 AUD) http://www.ebay.com.au/itm/360536631340?ssPageName=STRK:MEWNX:IT&\_trksid=p3984.m1497.l2649
I have several heatsinks laying around but I think I will use this one, but with fan removed due to size restraints. The mini fan will be used instead (Intel CPU cooler+fan $12.95 AUD):
http://www.ebay.com.au/itm/290681579846?ssPageName=STRK:MEWNX:IT&\_trksid=p3984.m1497.l2649
And of course, the torch! Eveready Dolphin $13.59 AUD:
http://www.ebay.com.au/itm/191038431988?ssPageName=STRK:MEWNX:IT&\_trksid=p3984.m1497.l2648
Now I couldn’t wait for the torch to arrive so I could start planning it all out, so I bought another one from Woolworths for about the same price. I figured it couldn’t hurt to have spares, and if I don’t need spares then I can make two torches.
I bought extra LED’s and an extra power converter too because of the time it takes to ship, I would hate to blow one up and then have to wait another month for a replacement to arrive. As above if I don’t need spares I can potentially make two torches.
Please forgive the crude nature of my very rough, 2 minute schematic courtesy of MS paint:
http://i.imgur.com/JuKnsUR.jpg
It is just to illustrate the rough layout of the components in the new 100W hacked dolphin.
One thing I’m not sure about yet is fan placement. Ideally I’d like to mount the fan on the heatsink however I don’t think there will be enough room, as the inside of the torch drops down. I will have to run some tests to see how hot it gets with no fan, and how hot it gets inside a sealed container. The key will be insulating the heatsink/LED from the reflector as it is only plastic and I fear it will melt on contact, but I don’t think the heating of the ambient air inside the torch would be enough to melt it.
I’m thinking the best place for a fan would be at the rear of the torch, then drill some ventilation holes around the heatsink. But again this will all be determined in the course of testing. It may be that the plastic is not resilient enough for the heat produced, but I’m quietly confident I can work around this.
I’m thinking maybe insulation around where the LED attaches to the reflector. The LED and heatsink will have to be attached to the reflector assembly as the whole thing twists off. I will use quick disconnect wires to allow the relfector/LED/heatsink assembly to be removed.
I don’t know much about insulation but I was thinking maybe some of this stuff?
or this?
Anyone with experience with insulation let me know.
So I couldn’t wait and decided to tear one apart. I probably won’t get all of the other parts for another month or so… waiting will be agony!
http://i.imgur.com/RtwR6Q5.jpg
http://i.imgur.com/wNFLnyQ.jpg
You can see not alot of room behind the heatsink. The battery has plenty of room, actually it’s almost identical to a 6v lantern battery, except half the width.
http://i.imgur.com/dTPAhGY.jpg
I removed the metal bulb holster thing
http://i.imgur.com/oB15fSt.jpg
Here’s all the parts I don’t need:
http://i.imgur.com/ywMmLwE.jpg
And here’s the pathetic little incandescent bulb… bye
http://i.imgur.com/TuGta4W.jpg
Will post up the build as it progresses… stage 1 = wait for parts from China.
Ok apparently I can’t post images with [IMG] code…? I’ll just post links then ![]()
