So I have been out of the modding game recently but I decided to use up some spare parts and built my version of the MTN “Mega M6”. No, it doesn’t make exactly 13,333 lumens, just a number I got at one point, it is between 13k and 14k depending on the batteries and charge level.
Cliff notes version:
Had spare parts, decided to build Mega M6
Decided to run it in a 4s3p setup instead of 12p
realized doing this would make it FAR too powerful to be useful at 280w+
added over 6 feet of wire to reduce the power to a more reasonable ~200w (~150w with the GA cells I use)
converted tailcap to 4S and used a TA driver that made the 4S conversion rather simple
got a completed light that outputs 13-14k lumens of beautiful Nichia 319A 5000k 80cri white goodness
Long detailed version:
A BLF member was nice enough to make me an aluminum slug spacer to raise the tripe optics up to the lens and the rest of the parts except for the mcpcb’s I had laying around (actually got enough to build 2 more lol).
So this is an M6, I had it modded with XP-L HI’s and while it was good and made 4k lumens, I just never used it compared to my other SRK’s.
The mod was pretty simple really. I put the spacer in, drilled a hole for the wires and then reflowed the mcpcb’s. I then wired up the LED’s with 18 AWG wire in a 4s3p config in order to vastly reduce resistance losses.
I put the head back together and started playing with it on the bench power supply. I quickly realized that this thing was going to be a monster if I was not careful. Wiring it up in 4S means that it can achieve much higher output then if it was wired in 1S (Richard said he gets around 40-50A out of his). I maxed out my power supply at 15A (equivalent to 60A at 1S) this is already over 200W of power and the voltage was only a bit over 13V!
Some math showed me that it with high drain cells I could easily see 20A+ (80A+ at 1S voltage) if I didn’t do something. Seeing as 280W+ would be far far too much I decided to do something. I added over 6 feet of 20awg wire as a crude resistor to drop the power!
This increased the voltage at 15A to around 15V which was much more reasonable and means that the 30Q’s should also give around 15A by the math (turned out this was correct).
So for those that have asked if running a SRK in 4S will net you more power then in 1S. The answer is easily yes.
I then put together a TA46-Multicell (the one that splits the voltage instead of using an LDO) and put the head together. Only to then have to rip it apart again as I tried to track down an issue with the driver. Never did figure it out, spent an hour on it and then reflowed everything and it suddenly worked. So some joint must have been bad.
After that was sorted I then had the hardest part of the whole build, lining up the driver with the battery tube so that the springs were centered in the bores. Turns out if you do not tighten down the centering ring real tight after each adjustment, it will just change every time.
Last came the tailcap mods to convert it to 4S. I used the multi-cell tailcap for the Q8 and set it up for 4S. I used some 1/8” brass rod I got for $3 from lowes to create locator pins in 2 of the holes. I simply used a touch to heat them up and soldered them to the screw holes in the PCB.
I then drilled a hole in the tailcap, sadly the M6 doesn’t have a divot in the tailcap to center the drill bit on but I got it almost exact by using the tailcap as a guide through the battery tube.
I inserted a screw into the tailcap with a small o-ring for water proofing and then used a nut to clamp it in place.
The tailcap pcb came next, the center hole went over the screw and then another nut over that. Lastly I added yet another nut on top to tighten against the last nut so that it would not loosen when taken the tailcap off.
Thats it, the 4S conversion was really quite simple and the light works great. I think I will upgrade to narsilM later as the LVP is kicking in early on the 1.2 I am using.
The results are quite good. Around 13-14k lumens with 30Q’s @ ~14-15A although I run it on GA’s where it is closer to 10A and around 11k lumens.
It has some great 319A 5000k 80CRI LED’s that give a nice wall of pure white light. The best flooder I have yet.
It is funny though, it is not by brightest light and since it is so floody it doesn’t even seem as bright as it is. Still very usable though and I think it will become my standard around the house light.
Now for some pictures of the completed light:
Here it is hanging out with a few of my other SRK’s:
Lights in order:
Mega M6 - 13.5k lumens
8x XM-L2 U2 3D - 10k lumens
8x XHP50 J4 1A - 17k lumens
4x XP-L HI V2 3B - 4500 lumens
These are all great lights. The XM-L2 is very close to this mega M6 except that it doesn’t have DTP due to the stock mcpcb and it is in 1s. The output quickly drops down to ~8000-8500 lumens due to this. The tint is good but not quite as good as the M6. It is a trowier beam though as would be expected from the larger reflectors.
The xhp50 is a lumen monster, very bright but once again lumens drop off due to lack of DTP, they settle around 12-14k IIRC. Ugly 1A tint, only keep it around because it is my brightest light right now.
The 4X version is very nice indeed, very close to what the Q8 should be like except with XP-L HI’s. Good combo of throw and flood and still had good output as well. I can’t wait to take it to the next level with the Q8 and XHP35’s, should be 8k+ lumens and great throw.
Here is a first for me, some really bad beamshots in the same order as above:
Well, this is how I spent my weekend.
