171mph Backwards
Here’s a record that is terrifying.
Got a spare 2.1 million? You too can get to and away from, well, everything.
All the Best,
Jeff
Not me, even if I did have the $
Thats nuts. How does he keep the steering wheel steady.
I wonder if they had to recharge the thing between runs?
Not that hard to implement in software if, as with most EVs, the power steering is electronic; works the same way as forwards. If not, same way as it works forwards with traditional hydraulic power steering.
Most fast EVs usually get a couple of full power runs before needing to recharge, IIRC.
What about aerodynamics? :man_facepalming:
I’m not supporting risking a life to have an entry in book of records.
Was wondering too, either they specifically designed the car to be “reversible” or it must have not been a pleasant “flight” backwards
Sounds a bit like Chitty Chitty Bang Bang:
In 1921 she won the Hundred M.P.H. Short Handicap at Brooklands at 101 miles per hour, and in 1922, again at Brooklands, the Lightning Short Handicap. But in that year she was involved in an accident[1] and never raced again.
[1] This is a polite way of putting it. In fact CHITTY-CHITTY-BANG-BANG suddenly went mad with rage about something, and with the Count at the wheel, got out of control and charged through the timing-hut, very fast, backwards!
I’m not sure about the battery.
But I’m fairly certain I would need to recycle my underpants after that.
All the Best,
Jeff
You’d probably have to be super careful with the steering or you wouldn’t be going backwards for long.
