17mm driver options?
I posted over on reddit, but I know there are some knowledgable folks here that dont go over there.
Anybody have a recommendation for the best 17mm driver available for mechanical switch lights? Considerations are:
  • cell choice (alkaline, nimh, lithium)
  • minimum output
  • peak output
  • efficiency
  • consistent regulation
  • UI
I recently bought a Convoy T3 and found the minimum brightness on lithium cells to be much too high. I would just use AAs, but runtime tests show much decreased efficiency over other dual fuel options on market. I read about the DrJones H17Fx and it seems like a great option for 14500 cells, but it does not have boost circuitry for using AAs, which is a feature I value. Regardless, I only found them on mtnelectronics and I get an error when adding to cart. The Reylight Pineapple driver seems to be a contender, with good aa performance and moonlight on boost and buck, but the buck circuitry seems quite poor, with bad regulation and low runtimes on lithium cells. Convoy has two dual fuel 17mm drivers, I am not sure what the difference is between them. Perhaps the lower powered 3A one has a suitably low 1% mode, but I do not know about efficiency compared to the driver I have.
Is there anything dual fuel with good efficiency and a moonlight mode?
1.5A and 5A both have a moonlight too high, but efficiency and regulation is good, all sustain 30%. There’s old boost-FET T2 driver that will fit, has low moonlight but only works with lower power LEDs, mine was destroyed by LHP531&Lumintop 920mAh but worked okay with Eneloop.
You’re probably looking at 3A/6A T4 driver, that won’t fit into T3.
