edit:
Oops, wrong forum, and no delete button.
sorry
UltraFire 12W 1600lm <—He-he,
CREE XML T6 LED
High, Low, Strobe
116mm x 30mm (Head Dia) x23mm (Body Dia)
Battery Type: 1 x 18650
ebay store, MXQ Tech
$8.32 shipped
edit:
sorry
CREE XML T6 LED
High, Low, Strobe
$8.32 shipped
You can edit your post and also the sub-forum.
BTW. Its 7,99$ from Banggood. Might even be able to use BLF discount on top of that.
Thanks, I’ve not looked for the 18650 powered unit, thought the price was good, wrong I waas <—stutter, uh-duh-uhh
Just picked up on from here
Didn’t need but could not resist. I will just give it as a gift to someone
Err-uh, that’s the same seller I linked;
Seller :
mxqtech (443152
This model is actually called a Sipik SK98
I have a Raysoon 398 and gave away an UltraFire like this one http://www.ebay.com/itm/UltraFire-12W-1600lm-CREE-XML-T6-LED-ZOOMABLE-Flashlight-Torch-18650-Zoom-in-out-/370765285520?pt=US_Flashlights&hash=item5653554890 , but with 5 modes. The knurling is not as good as that of the Raysoon. I payed more than that for it.
Yes, thanks for the heads up!
Been using one at work recently in place of my sk68.
Today I found the next mode memory seemed to stop working, which was a pleasant surprise. perhaps the heat got to it?
Yesterday I took a 3400mAh Panasonic 18650 cell down to 2.72V in this. It was significantly dimmer when it got down to this voltage. But these cells can go down to 2.5V so it’s ok.
