26650 Battery Charger
Is there a 26650 battery charger that actually fits a fargin' 26650 li-ion battery?
Four Sevens.
http://www.4sevens.com/product_info.php?cPath=53_434&products_id=2582
Yeah but does it actually fit a 26650 li-ion battery without using magnets or wires.
tr 006?
http://www.manafont.com/product_info.php/trustfire-liion-battery-charger-for-2665025500267001865016340-us-plug-p-8851
Charges @1500mA
or
http://www.manafont.com/product_info.php/trustfire-dual-channel-liion-battery-charger-for-2665025500267001865016340-tr006-us-plug-p-9985
Charges @1000mA (per rail)
I think both have been reviewed by users here and were recommended.
http://www.intl-outdoor.com/ml102-usb-charger-for-18650-26650-battery-p-243.html?zenid=690b7d805ec5b78fac33eafbb73f8d1a
I reviewed the Trustfire TR-005 26650 Charger the one in the first picture.
https://budgetlightforum.com/t/-/8049
Sysmax intelicharger Can charge 2 at a time. https://budgetlightforum.com/t/-/7763#comment-153239
0.75 amp is a bit low and slow for 26650 batteries and you sure they will fit.
I do not have any to test myself. But HKJ has. He also mentioned there may be a problem with smaller button tops. https://budgetlightforum.com/t/-/8112 I just like the versatility of the sysmax being able to charge multiple chemistry's and even 26650's when get around to buying some.
My 4Sevens fits the new Trustfire 5000 button tops and King Kong flat tops, and the 4Seven semi-flat tops all perfectly and no magnets required. It charges the KK and 4Seven batteries to 4.2v, but only seems to charge the Trustfire's to 4.18v.
Got a link?
Thanks for all the other suggestions guys!
Sure Fishin, here you go.
http://www.4sevens.com/product_info.php?products_id=2582
[quote=Richie086]
Sure Fishin, here you go. It also comes with a 12v adapter to plug it into a cigarette lighter to charge the batteries. It's good for me because I also have a small 50 watt solar array with ample 12v power for emergency useage. There may also be prices slightly lower if you shop around, but I used my CPF coupon code for a slightly less price.
Thank you sir!
This will work pretty good:
http://www.ebay.com/itm/300682325929?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Fits 2x26650, charges 1x1000mA or 2x500mA.
Once the link expires, it's cyberport888, Keygos M10 + 2x26650 + Charger Set.
I got one, and it terminates spot on 4.20V according to my little LiPo 1S voltmeter, and at 4.23V according to my cheapest of the cheap DMM.
At the moment I trust the LiPo 1S voltmeter more than my DMM.
Thanks but I need just the charger. I'm looking at either the manfont or the 4sevens charger but still open for other suggestions. Thanks again guys!
Xtar SP2, I am looking at buying one myself since I now have multiple 26650 lights and the WPII 2 only fits 1 26650 at a time, otherwise I may make a couple of "sidecars" to use with my WPII 2 so I can charge 2 26650s at the same time.
Let me know how it works out.
I have the Xtar SP2 charger and It is my new favorite charger with it’s ability to charge at .5a, 1a, and 2a which is selectable with the push of a button rather than using some cheap slider switch. I did some testing of my own and it seems to follow a pretty good CC/CV algorithm. It accepts anything from a 50mm length on up without spacers and can even handle 32650s. I tested current output and it does what it says it does. 2a pretty much stays dead on 2a during the CC stage, for example. More importantly, it does not overcharge even IMR batteries like some other chargers. It always terminates properly. It fits 2 x 26650s with ease and 2 x Feilong 32650s with a little loading care.
Also, the quality is very obviously way better than the Ultrafire chargers.
