I would like to step up from the 700-800 lumen range because… Reasons.
I don’t care if a flashlight can put out 1 million lumens on turbo for 2 minutes, i’m looking for something that is able to hold 1500-2000 lumens for longer periods of time. It’s not an issue if the light is on the chunkier side (it should be, because it has to be able to deal with the heat), but I don’t want to go crazy, around ~300g max. In terms of beam pattern i’m looking for a balanced beam, definitely not super throwy, I want some decent flood, but nothing crazy. Something like a Convoy M1, but if it’s a bit more floody, that would be good. I’m guessing even with a similar beam pattern, a more powerful light will have a brighter spill anyways than the M1?
I don’t need built in charging, I don’t need a super fancy UI, but more than 3 brightness steps would be nice. Budget price range. I mainly want something that takes 26650s, but i’ll consider other options.
I looked at a lot of reviews and so far the only suitable light that I found is the Convoy M3. It’s cheap, good quality, and according to the reviews it can hold a rock steady 1400-1500 lumens until the battery runs out. But like most reviewers, i’m not too stoked about the super basic UI. Some extra modes between 10% and 40, and 40 and a 100% would be nice. Is there a different driver with a better UI that works in the M3 and it’s easy to swap in (by easy I mean just soldering two wires)?
I have the M3 and it will hold that level for a long time. Lots of mass, good grip handle. Be sure to use these batteries or some version that uses the same cell.
Shockli IMR26650 5500mAh or Vapcell INR26650 5500mAh
That sounds very promising. Where did you get that from?
I have a M3 and it’s a very good deal indeed - except for the UI. An updated version would be awsome.
How about the Astrolux MF01 Mini? First batch was stepping down too early because of poor heat management and design shortcomings, but the newer version should be just right. Aux leds and USB charging are the icing on the cake.
The Astrolux EC 01 is also an amazing deal but runs on 21700.
Sofirn 26650 SP33 has good reviews too i believe - i don’t own that one.
You may also want to have a look at the Emisar D4SV2.
Thanks for the suggestions, but at least based on what I can find it looks like neither of these lights can hold the output that I want. Not a 100% sure on the MF01 tho. I found this thread here and it doesn’t look promising:
Even after the mods it could only hold a 1000lm, just. Not sure if this light was from the first batch, and how the current stock lights compare to this modded one.
I looked at so many reviews and the M3’s ability to hold ~1400lm basically forever is starting to look better and better. I wonder if it could hold a bit more if it had a better UI with some extra steps.
I have a U21 that can run for a pretty good time and not get to hot or run the battery down fast.
I use a single Shockli 26650 IMR 5500mAh.
This is my daily used light for the last 6 months that had only 1 charge 6 months ago.
Manker U21 1560 Lumen Pocket Thrower CREE XHP35 HI LED Flashlight
@HollyBoni: I know you want a single 26650 cell light. However, for what it’s worth this light with 4-18650s seems to run at 1500lm or so for 200 minutes… Convoy 4X18A
Where did you get that it maintains 3000 lumens for hours??? Its output at turn on is 2,740 lumens and quickly dropping. It can maintain about 107minutes at 1,000 lumens. Still good but nowhere near 3,000 lumens for hours.
Zebralights do maintain brightness after stepping down but the stepped down levels are much lower than the rated turbo output, which is typical of all flashlights. Only Olight and Fenix spec their runtimes with honest step downs on their websites and honest ANSI 30s output levels. Zebralight like Acebeam and many others exaggerate their output 20% or more above actual output.
There don’t exist any 26650 lights that can sustain 3,000 “real” OTF lumens.
I have never known Zebralight to exaggerate output. Generally, they are accurate with output to 2 decimal places, but this is assumes they have tested the light, which is ordinary for them to do. Looking at the SC700d product page it is pretty clear they didn’t test it yet. Also, every Zebralight product page for any flashlight that steps down indicates that it steps down. The SC700d doesn’t indicate any stepping down, which is what threw me off. Even the brightness testing curve you posted above doesn’t appear to indicate any stepping down… just rapid drop off from maximum brightness to 1000Lm, and there it appears the current regulation kicks in. That chart squeezes a lot of time in the horizontal axis, so maybe there is a tiny bit of regulation at 2500Lm, followed by an intentional step down, but it is odd that there is no mention of it on the product page.
Just a heads up the product page does list a “stepping down”, rather every zebralight product page mentions it in a similar way to the point its basically copy pasted with adjusted values for different lights.
you see
“High: H1 475 Lm (3min, then 352lm, total 0.5 hr) ”
Most of Zebralight model product pages have such an indication of step down in the same place (but I wouldn’t say it is copy and pasted, except where mode brightness levels are identical, which is rare).
But the product page for SC700d does not have an indicator there:
“High: H1 3000 Lm (PID, approx. hours) ”
See the difference? No indication of step down. This may be an oversight by Zebralight’s web designer or marketing copy guy, but the fact is, there is no indication whatsoever of step down on the SC700d product page.
My FT03 XHP50.2 can do continuous turbo (I’ve turned off the step down) until the battery dies if I’m walking and it’s –15 or colder. Can’t say none and not specify the conditions
