I bought this headlamp on ebay:
It is a XM-L T6 emitter with 2x18650 batteries in parallel on the back of your head.
I assumed the driver sits in the lamphead and is maybe a “regular” flashlight driver.
Unfortunately the board is under the two 18650 in the back of the holder:
If i understand this circuit correctly the lamp is direct driven with PWM modes:
- controller: CX812
- Mos-Fet: A1SHB
What i don’t get are the 2R2x4 resistors (3x0.3Ohm parallel)
Anyone an idea what they are for?
Current restriction?
I measured some stuff while on high mode:
Battery Voltage: 3.86V
Board-in Voltage: 3.76V
Board-out Voltage: 3.39V
2R2x4 Voltage: 0.16V
Emitter Voltage: 3.00V
Battery/Board-out Current: 1.40A
what i intend to do:
- first i’ll replace the wires from the batteries to the board, 0.1V drop on ~3cm at 1.4A is not a sign of good/thick enough a connection.
- i’d really like to replace the wires from the holder to the lamphead as well but i didn’t manage to unscrew the pill (yet)
- get some more power to the lamp: change the 2R2x4 resistors? but first i’d like to know if this Mos-Fet can drive more than 1.4A
- if there is enough space in the head i’d like to strip the driver from the battery-holder and put a nice flashlight driver in the head!
What do you think?
Can i boost the LED to the 3A it deserves?
Has anyone a tip how to unscrew the pill without some split ring pliers?
update 23.Nov:
I managed to disassemble the head, found some info about the components and made some first (temporary) improvements.
The CX812 controller is a dedicated LED controller (from china):
- Operating voltage: 2.5V-5.5V
- Operating current: <1mA
- Operating temperature: ≤ 85 ℃
- Maximum static power consumption: 0.5UA
- Maximum output current: 10Ma
Pin Description:
1: LED1 signal output
2: LED2 signal output
3: LED3 signal output
4: GND
5: MOD1: modes selection
6: MOD2: modes selection
7: KEY: switch
8: VDD
the mode selection should allow high, low, flash, slow flash and SOS.
But that’s what mine does (both open is standard):
- 0,0: high - low - flash - off
- +,0: high - low - off
- 0,+: high - off - off
- : high - off
the A1SHB (SI2301DS) is a MosFet with max. current 2.5A
what i’ve done
- replaced the wires from batt to board (0.75mm2/AWG18)
- temporary wires from board to head (0.75mm2/AWG18)
-> result: current is up from 1.4A to 2.3A (530lm to 760lm)
what next:
- i am near the 2.5A max current of the MosFet therefor i won’t change the 2R2×4 resistors.
- i’m looking for some silicone wires to permanently connect the lamphead with the bat. holder
- maybe later think about putting a flashlight driver in the head
