Been using it for half a year now - no problems so far
+/- A bit heavier and bigger than other 2xAA lights like the C3 with extension tube for example.
+/- Doesn’t throw all that far (which is probably to be expected of an XML without a large reflector)
+/- I once accidentally disassembled the head when I just wanted to change batteries. Make sure to only unscrew it near the H - M/L lettering, not where the silver head meets the body.
- According to the website, changing modes works as follows:
“In tightened position: high output mode (100%)
In loosen position: medium output mode (33) → low output mode (10) → repeat (please switch between the medium and low output modes with the tail-cap switch within 3 seconds. After 3 seconds, the flashlight will memorize the medium output mode automatically and will be in that mode after being turned on again)”
This last “memorizing the mode in the loosened position” - bit doesn’t work for me. In the loosened position, my light always starts on medium.
To me, the positives outweigh the negatives and I would absolutely recommend this light (to anyone who doesn’t need it to start on low mode).
hanshanshans, I think the description was just a little lost in translation. I think what they meant is that when it was off, it would revert back to medium. That works for me, though. I would rather mode memory, but I can deal with starting in medium.
They aren’t going to be carried on-body, so the weight isn’t a huge problem.
Will any batteries be good for keeping it in the car?
What batteries are good for cold weather? By cold, I mean 20*+F
Lithium primary cells work well at low temps and have a long shelf life. I using alkaline, I'd store them in a plastic bag outside the light so they don't destroy it when they leak.
Thanks Bort. They didn’t mention it had a mid level on the other site. I don’t mind if it’s not 450, as that’s not really what I am looking for.
The specs list actually contradicts what is in the pics, so it really doesn’t surprise me that some stuff is off. The spec list says 450/128/13 while the picture says 450/210/30
Its sitting in the car, i don’t like it at all, the runtimes are low, the lumens are not high, the light is not well designed, and it makes random sizzling/hissing noises while its running, i haven’t used it since last year and it works but i don’t recommend it.
I think you should seriously consider the starry light linked above, it may be 4AA, but it will put a smile on your face
I have tested these (except the super low, i use the light too much to test it, in 12 hours it dropped 10% which is what the batteries do when recharged and left for a day)
I should have mentioned the modes are
0.2%
2%
25%
100%
I suggest using the 100% for less then 10 minutes at a time, the head will get hot enough to burn you if left on too long, think of it as a manual turbo, you often see 30-90 second turbos on other lights, this is one you can control.
There is one quirk/flaw, sometimes when you switch modes it turns off instead of going into the mode, just change modes again and it will come back in the following mode (i call it the missed mode issue)
