We need the programmable one. There are 5 versions (AFAIK)
1 mode
3 mode programmable
3 mode not programmable
5 mode not programmable
6 mode not programmable
The one you got is the 3 mode not programmable. This flashlight (akoray k-106) has a identity crisis and is a big problem for us, because there are 5 versions with same model name and model number.
The 3 mode programmable has body in gray gunmetal color, has anodised threads, the tailcap button and o-ring are not GITD (are orange) and the driver is epoxied inside the pill.
All other versions have brownish/goldish body and have not anodised threads, have green GITD tailcap button and orings. The driver is not epoxied
Thanks for trying to locate this light. But as Fran82 says, there are many, many versions of the "Akoray K-106". We tend to prefer the version that has 3 "infinitely variable" modes.
I have some question still not very clear , What does programmable mode mean , can anyone explain it , then i can offer the right information to the manufacture .
When the light is On and you press the power button 5 times quickly, you enter a programming mode where the light flashes 1 time to indicate Mode 1 and then starts changing the brightness, strobe frequency, etc. When you see what you want, you turn the light Off and On fast and the brightness level you wanted is saved into memory. Then it blinks twice and goes through it again to set Mode 2, then Mode 3. You are able to set each Mode to any brightness or flashing mode that you want. If you want Low, High, Strobe, you can set that. If you want Med, Low, High, you can set that. Anything you want in those 3 modes.
If you find it …they will beat a path to your door …Odd that no one built a good version of it >>yet it makes perfect sense someone would make a bad version of it
..I'm looking for one ..let me know if you find them
Well if they have it .... then I'm curious why someone on KD is using the name of a BLF member (brted)who has posted above....^
something doesn't add up ..I'm betting KD doesn't have it .. or brted would have spoken up to say so instead of telling Daniel how the programing works .
It would be a nice surprise if he had the programable ones and didn't even know how it.
And somebody here mentioned that their KD order of a 3-mode K-106 was later cancelled and refunded by KD. I think they might not have them anymore there.
I learned the hard way, I didn't research further than the reviews at the bottom of the page on DX's site. I also bought a pair of 14500 lithium batteries in the same order.
Nice little light with AA's alkaline's, worked for 3 days. Tried the 14500's, 4 minutes, poof!
Emitter just flashes now. I have the driver off the back and I'm looking for a 3-mode H-M-L 15mm driver to replace the burnt one. Something like 1.0A high, 2.5 - 6 volts perhaps, NO STROBE!!!
As a matter of fact I' going to start a new thread requesting that info from the whole site!
Good luck, choose carefully before using 14500 lithium's.
