Hi Guys,
I am making room for more XM-L2 drop-ins, so I need to clear these XM-L gen 1 top bin emitter drop-ins out. I have a very limited number of these for sale.
I decided to offer an amazing 30% off + Free AR Lens ($4.99 value).
To order, use one of the links below and the coupon code: X60L30
Remember, quantities are limited!
Specs:
• Powered by Cree XM-L
• Modes: 3 Mode (High, Medium, Low)
• Current: 1.5A +/- 100mA
• ~460 OTF Lumens (CW U2)
• Input Voltage: 3-6v
• Supported Cells: 1x18650/17670 Li-ion cells or 2x CR123 Primary Lithium cells. Do NOT use 2x RCR123/16340 Cells.
• Size 29mm (40mm with spring), Weight: 20g (0.7oz)
• Compatible with: SureFire P, C, Z
Features:
• All aluminum for better heat transfer (compared to brass).
• The first uni body constructed P60 drop-in module (with the reflector, and heatsink machined from one solid piece of aluminum).
• Precision machined aluminum OP (orange peel) reflector.
• Reverse polarity input protection
• Over discharge protection ~2.75v (Only applies to High and Medium modes)
• Gold plated spring
• Linear Current regulated. No PWM.
• Thermally potted driver
Here are a few pictures:
Link to Cool White U2: http://edcplus.com/x60l-3mode-cool-white-u2-cree-xml-p60-dropin-for-surefire-p-106.html
Link to Neutral White T6: http://edcplus.com/x60l-3mode-neutral-white-t6-cree-xml-p60-dropin-for-surefire-p-65.html
