3S 26650 12x 219b Mag build - help finding a driver
I have been deep diving over the past week bringing myself back up to speed on flashlight modding, and am stumped on what driver I should use for my build. I know I need a 12v to 3v buck circuit, and that my build must be very commonly done during the Mag mod craze, but I can’t find what I think I need available anywhere. And I definitely don’t want to pop my rare 219b leds.
My theme for this build is 3D mag vibe but way brighter. Long running, doesn’t overheat in 15 minutes, wall of light. Basically what the 3D mag was to me as a kid, when 60 lumens was hugely bright, and 500 lumens was the sun. I want at least a thousand lumens out of this in high cri where I don’t have to worry about babying the light.
Host:
3D incan Maglight
MCPCB:
I’d really like to find a 50mm mcpcb that spreads the leds further apart, but can’t find anything like that without contacting custom pcb makers. So I’m choosing the following because it seems well made and will let me use the MCPCB style for smaller builds in the future if I want. And it’s available in the USA.
SL 12x 3535 Copper MCPCB
https://www.mtnelectronics.com/index.php?route=product/product&product_id=1005
LEDs:
12x Nichia 219b 2700k
I love this particular LED and have them on hand and think it would be perfect for this build. If you think there is a single led that would work better for it overall, let me know.
Batteries:
3x Vapcell 26650 7000mah 30A K70 Rechargeable INR Button Top Battery
In series with magnets between the cells to allow continuity. I suppose I’ll have to machine a bit from the inside of the tail and fit a lower profile spring. Plus a sleeve in the tube to keep the width proper.
Heatsink:
I have some aluminum, brass, and delrin on order I’ll machine down to fit inside the head of the light and adapt to the contacts for the bulb, that I’ll make room for the MCPCB in, and put thermal paste around the outside to help contact to to the head of the light. I know I could just get a p60 adapter from malkoff, but I figure it will be more fun to try and make my own since I have a lathe and mill.
Driver:
Here is where I’m stumped. I know I need a buck for the 12v from the cells down to the 3v the 219b needs. I figure each led needs 2.5A to not be over driven and hot and still provide good output. But 12x in parallel has a higher amp need, right? So 30A out of the buck driver? Or, if not, then 2.5A out of the buck driver. Both of which aren’t options on MTN electronics who sells the mega mule components my MCPCB is part of.
Am I way off on my assumption? And if the LED board really does need 30A, I should be good with the 30A rated 26650, right?
12 3V LEDs at 2.5A each that close to each other without a proper heatsink? I wouldn’t even think of that.
You write you want at least 1000 Lumens, so I figured you will severly underdrive each LED with like 350mA or something to get to 1500lm or whatever, but 2.5A per LED makes ~1000?ish Lumen per LED, so 12k Lumen for all 12.
You can drive that with enough thermal mass, sure, but I wouldn’t want to drive those LEDs without a driver with thermal protection.
Had the same problem - finding a high amp driver with 12v input for 3v LEDs is problematic. Easiest solution is to use 1x 6v LED and this driver from Kaidomain:
One can use it witn 1x6v LED, or 2x3v LEDs in series - Convoy sells LHP73B on 16mm, they will fit inside Mag 3D (You can even fit 3x16mm PCB inside 3D with a little bit of sanding them down in certain areas). 2xLHP73B with this driver should get You about 6000 lumens. Downside - 70CRI. But tint is quite pleasant…
Edit:
I read OPs post one more time - You plan to use other radiator, than I plan in my Mag project - since You have 50mm radiator diameter You should be able to fit (that needs to be verified) 4x 16mm PCBs. 4xLHP73B will get You 7500 lumens with driver listed above. Stock Mag switch should be fine with 5A of current.
Edit 2:
If You choose to go with Mag 2D instead of 3D, You can get this driver from Convoy along with LEDs.
30mm 6V 8A driver for L6 XHP70.3 - Convoy flashlight.
And also there are 6v LEDs with high CRI - SFT70 3000K, You can use 4x in parallel. With 8A driver You should get +/- 3800 lumens.
And kaidomain has AR coated glass for Maglites.
This is a great suggestion and gives OP a lot more flexibility.
If OP can find a 12V to 3V driver, then 4xSFT40 3000K in parallel is a great combo.
If OP can find 12V to 6V driver, then 4xSFT70 3000K in parallel.
If OP can find 12V to 12V, then 4xSFT40 in series or 4xSFT70 in 2S2P would both work.
These emitters are much more efficient and robust than the 219B, while giving better quality of light. They also let you choose 4 TIRs, one for each emitter, to customize the beam profile as you like it.
Since when does a SFT40 deliver better light than 219b?
If there is a 12v to 6v driver, a 2S2P with 3V LEDs is also possible
Or just use 3 3v LEDs in series, maybe even 7070? LHP73b should come out in high CRI at some point
For 6V LEDs, keep the B35AM in mind.
For 12V LED - FC40?
Do you want substantial throw or is flood alright? What about a mule?
WB, hiyaside!
It’s hard to find color reports of the 219B 3000K, but here’s one indicating +1.1mDuv, 95.2 CRI, 84.5 R9, compared to the consistent 97-98 CRI achieved by SFT40. There are also different bins of 219B floating around, and if you’re unlucky you can end up with one that’s a decent bit greener than 519A as in this comparison. On the other hand, all 4 of my HB4 binned SFT40/70’s are a bit rosier than a halogen bulb.
Nichia’s LEDs tend to struggle with blue spike and cyan dip, while Luminus’s 95CRI 3000K does a great job addressing this. This is particularly evident when comparing the 519A against SFT40:
Of course, OP can choose to use the 219B if they so desire–the 2700K has a good chance of faring better. I personally find SFT40/70 a better engineering solution that also provides more flexibility in drivers/optics. A single SFT40 has the output of 2x219B in parallel; for the SFT70 it’s closer to 4x219B, and has no difficulty pumping out 1000+lm even with a single emitter. And as @L4M4 remarked earlier, 12 LEDs is overkill for 1000 lumens.
If OP is willing to wait, this is a good solution if OP wants to maximize the output/efficiency and minimize the cost as much as possible.
For any CCT other than 3000K, B35AM is a fantastic emitter if one doesn’t need throw and drives them conservatively. For 3000K, the SFT70 is strictly superior in every way: standard footprint, compatible with standard optics/gaskets, more output, better thermals, better power handling, higher intensity…
This estimate is a bit optimistic, as even the 4500K variant barely puts out 550lm at 2.5A. But I do agree that 12x of them is unnecessary–more LEDs at a lower current is always more efficient, but the extra efficiency diminishes extremely fast with the number of LEDs. Eventually the extra efficiency is outweighed by extra optical losses.
Wow thank you so much for all the detailed and knowledgeable responses. This is extremely helpful and there is a lot of insight in where I was making things hard for myself.
To further clarify, yes a mule of any sort is what I plan to build. It’s the most useful beam for something like this, which will be a worklight and general purpose light. Plus, it’s easier to make. I don’t have nearly enough mules in my life, anyway.
I know the “easy” route is just get the Malkoff P60 adapter (which is very well designed and made and well worth the money), a cheap 2x 26650/21700 adapter, and use the triple 219c mule p60 that I already have and like and don’t use nearly enough. But then I’ve just spent money to quickly N+1 my collection, instead of the fun challenge and learning experience of building my own. That, and, leaving a whole extra cell’s worth of empty space in a 3 cell flashlight really bothers me. If I could find two cells that fit perfectly in the 3D body, I’d do that, but there isn’t anything larger than a 26650 that is common or provides better capacity.
While a 2D Mag is clearly the easiest and best platform, and C cell mags are the coolest and most svelte, my host is a 3D Mag because;
  1. It’s a great balanced form factor and a classic “big light”
  2. I just found one at goodwill for $2. I don’t currently have a maglight, this one was lost in a pile on a random shelf. Missing a button cover, ruined lens and reflector, the right amount of wear and nicks, but looking new internally. It was obviously a well used but not purposely abused 3D mag that makes the perfect host.
With what you’ve all said, 12x 219b is no longer what I want. I was thinking they might run cooler, even though I have an M44 with 16x 219b 2700k that gets plenty hot and doesn’t have the runtime I’d like. (it’s amazing, though). They would push way way more lumens/heat than I want. This can’t be a hot rod, I want something that utilizes the advancements of efficiency in LEDs to give a ton of lumens without being overworked. A “warm rod” not a “hot rod”.
The FC40 12v is something I totally forgot! I have one of those in an Emisar D1 that’s fantastic for anything but white wall hunting. Think I could just direct drive one off three protected 26650 at 12.6v peak and call it a day? That would offer the simplicity I’m looking for. I was previously thinking of mining dead LED lightbulbs for their COB boards for a 12v option, but wanted a better tint.
The XHP70.3 is also a great suggestion. I had previously looked at the 70.2, but saw reports of bad tint. But the 70.3 comes in 90 CRI 3000k, and is available in a 12v option if direct drive was feasible.
OR I could go with the 6v option and this driver, which allows me the simplest UI. I’d prefer just on/off, but the High/Low with memory would probably be much more useful.
Regarding the SFT40 and B35AM, one needs me to find a 12v to 3v driver, which is a problem, and the other isn’t easily available in 3000k. I do really like nichia, though!
Great to hear your thought processes behind this build!
The GT-FC40 is a good emitter to consider, and direct-drive probably would work. Though with a direct drive setup, the brightness can drop very quickly with declining cell voltage. The CRI is generally regarded as slightly lower than Nichia/Luminus options.
Cree 90CRI emitters are known for tint shift, green tint, and low R9 (deep red). You’re better off with GT or Nichia or Luminus.
The B35AM is 6V, but even better is the SFT70 3000K, which is also 6V but takes a lot more power and is not prone to burning up. If you like Nichia, I strongly recommend giving one of these Luminus emitters a try–to my eyes they are much more halogen-like than Nichia emitters, with a smoother spectrum in the blue-cyan region.
If you want good efficiency, multi-emitter is still the best way to go because efficiency increases with lower power per emitter. Depending on whether you can source a 6V or 12V output driver, I strongly recommend 2x or 4x SFT70 3000K in parallel for 6V, or 2x series or 2S2P for 12V. With 6V 5A output (as with the driver you found), 4xSFT70 3000K gets you 2600 lumens raw output, which is probably way more than you need.
If 3000K is fine, you can buy the FC40 for half the price from Cnvoy
For trying out direct drive, the LED should be cheap, just in case…
Or you buy 3 of them or how many fit…
You speak directly to my heart. I’m totally sold on going with the SFT70, based on this. I’m sorely tempted to get the 2700k version since it’s 95CRI and I really love the 2700k nichias, unless it would be best to go with 3000k for the “halogen-like” magic.
I wanted to avoid multi boards, because it’s easier to center a single board and it won’t look so messy, and leaves more heatsink material. But I can just relieve a wider space of room to fit 4 16mm boards easily enough I guess.
Going with a 6v setup, with the 6v buck driver, will be better for flat output, anyways.
STAHP I still want to try this too. I guess I’ll keep this in mind and maybe just do both.
I designed and had manufactured some 50mm 12X3535 mcpcb’s. Both in a 1-channel 12x configuration and a 2-channel 8x4 configuration. I can send you some, if you pay shipping. I’ll get you a pic of them later.
It’s entirely up your preference whether you find 2700K or 3000K more pleasing! Convoy only stocks the 3000K variant, which imitates a halogen lamp, while the 2700K variant imitates a traditional incan bulb with a long filament and no inner glass envelope. Incidentally, I’m in the middle of writing a post on converting a SFT70 3000K to 3150K, which looks like a well-driven halogen car headlight.
I see, multi-boards do tend to introduce more engineering complication, and to my knowledge, I couldn’t think of any good multi-emitter boards for 5050 emitters. But since you’re going with a mule, centering is inconsequential to the beam profile, and the only hassle introduced is the need to secure each of 4 16mm boards to the heatsink, perhaps by drilling extra screw holes.
Go for it!
When I snagged this $2 mag I already knew it was going to cost me waaaay more than $2 once I was hooked on modding again. But I may never financially recover from all these led options. :slight_smile:
I would go crazy if they were secured poorly or one was slightly off from the other. But I think I’d get over it. 2700k it is, because I really love that incan feel and it would fit well with the host.
That’s super kind of you to offer, and super awesome of you to go through the process of getting custom boards designed and made. I’d love to try at least one of each for this or another build. Especially since I have a bunch of nice LEDs to put on it. I’ll DM you now and you can reply whenever. :slight_smile:
I see :smiley: If you want the warm feel definitely go for 2700K–keep in mind that mules (without a secondary optic to mix the light) will always be cooler than the nominal CCT of the LED.
One super easy solution came to my mind - 32140 15A LFP battery instead of standard Li-Ion in series. It fits my 3D Mag, and is 3,2v. Also the voltage drop while discharging LiFePO4 is quite flat, meaning even without driver, direct driven 3v LED would give a rather stable output.
This is my homemade 32140 LFP insert for 3D Mag. It may not be the prettiest one - but it works :grin: You can see an add-on on the negative side of battery - serves as a “dummy” (32140 is only 140mm in length) and has USB-C charging built in - You can see a USB-C port on the bottom, so my 3D Mag is kind of rechargeable - but You have to get battery out of flashlight to charge it.
That’s pretty brilliant work there @Kazik ! I wonder if two of those would fit perfect in a 4D mag, for near infinite runtime and easy modification on a 6V system. Looks like four D cells would be 246mm, but you could probably fit a much shorter spring to make up the extra 35mm needed.
How are you adding power to the positive and negative of the cell from the bottom? Are you patching into a built in protection circuit?
I wouldn’t stress about it being pretty or not, as it looks like it functions great. The only change I’d make at this point would be to replace the tape with heat shrink tubing, or battery shrink tubing. But also, it works and I’m impressed with you for putting that together. I guess otherwise you’d need a charging harness with magnets on each contact.
You know, I didn’t know that, or hadn’t noticed that. Even more reason to go with 2700k over 3000k!
