I’ve been interested in the concept of ultralight headlamps for a while and decided to make a detailed comparison of four different models: Nitecore NU25 UL, Petzl Bindi, Black Diamond Deploy 325, and the Black Diamond Flare. I chose these based off recommendations from others, and also just what looked neat. (I also compared these to a more traditional headlamp in the form of the BD Astro 300)
I purchased these lights with the funds from the YT channel Lumencraft to make a video - I have no partnership with any of these brands.
Output was tested with the TKLAMP Flashlight Tester TK2303D, a laboratory-calibrated integrating sphere. Runtime measurements were done using an old Samsung Galaxy S6 with the ceilingbounce measurement app.
- Nitecore NU25 UL: 45 grams, $37
- Petzl Bindi: 35 grams, $50 (US Price)
- BD Deploy: 38.5 grams, $60
- BD Flare: 27 grams, $30 (though I got it for $23 on sale)
MEASURED OUTPUT (Lumens):
| Mode | NU25 UL - FLOOD + SPOT | NU25 UL - SPOT | NU25 UL - FLOOD | BINDI | DEPLOY | FLARE |
| ULTRALOW | - | - | 7 | - | - | - |
| LOW | 75 | 72 | 75 | 9 | 4 | 10 |
| MED | 268 | 256 | 259 | 143 | (Smooth ramp) | - |
| HIGH | 507 | - | - | 299 | 433 | 140* |
| RED LIGHT* | 7 | ? | - | 2 |
Some notes:
- Black Diamond only rates the Flare at 40 lumens on high. With the included batteries, I got 56, but when I used Energizer lithium cells, I got significantly more (140). This is because the high mode is unregulated, so output is entirely dependent on the cells.
- The Deploy has smooth ramping from High to Low, so you can set the output wherever you wish. The channels are nearly the same (Center and Center+Up being the same, Center+Down being a couple lumens brighter - more on that later).
- The Red light should be taken with a grain of salt as my sphere is not calibrated for these wavelengths. It could not even measure the Bindi’s red light (It seems to be a lower wavelength than the other two) despite it being notably brighter than the Flare’s red light to the eye. The Nitecore red is definitely the brightest.
- All modes are measured after a full charge, the instant of turn-on; they will fall with use.
I found all of these to be plenty powerful for all use-cases that I had for them - I rarely need more than a hundred or so lumens out of a headlamp, 400+ is more than I need personally so I was satisfied.
RUNTIMES
High Modes compared:
The NU25 performs very well, it starts at 507 and drops down to 175 lumens, sustains that flat before dropping again at about 95 minutes, and then sustains 80 lumens until dying at 210 minutes.
The Bindi has flatter regulation, from its max to 150 lumens, which runs flat until it dies completely at 160 minutes. Very good, and arguably better than the Nitecore for sustained output albeit a bit dimmer.
The Deploy falls behind the other two, falling over 30 minutes until it hits 100 lumens, at which point it very gradually falls until 145 minutes, where it trails off and dies. Not bad. Also note the performance over the first 10 minutes where it does hold its output better than the other two (despite being notably dimmer than the Nitecore)
The Flare is again unregulated, immediately falling until it’s quite dim at 30 minutes. It actually ran for a very long time (over 14 hours) with a very dim output before it finally died.
Less high modes compared:
(Because of the smooth ramping, I only measured high on the Deploy - it’s just here for reference.)
We mostly see the same pattern, just lower output. Nitecore’s medium still behaves like a high mode, with an extended time scale: it falls straight over the course of 30 minutes before stabilizing at 105 lumens, then stepping down to 65 lumens at 160 minutes. I like the low mode, but even that falls over the course of the first 15 minutes.
Overall runtimes where good on all of these, with the Deploy lagging behind the Bindi and NU25. In any case, bringing a battery bank is recommended (though I was able to use the NU25 for three nights in a row without charging it.)
BEAM PATTERN:
In short, I found all of these effective, and none of them pretty. We are dealing with cool white, low-CRI emitters across the board here.
The Nitecore offers both a flood and a throw channel, both of which are great at their respective jobs and can be used together. It has the best beam system overall imo.
Petzl’s Bindi has a great single LED that offered both enough throw and flood that I didn’t feel I was missing anything while using it. It does have strong PWM that is very noticeable on camera, but it was fast enough that I didn’t really notice it in person.
The Deploy also has a great beam pattern, though it doesn’t throw as well as the other two. Its main unique feature is the “variable-angle lens” - it has a floody emitter pointed slightly upwards, and another pointed slightly downwards, which can by cycled with a dedicated button. I found that this barely made a difference, and I feel like it was a wasted feature. I think a floodlight, spotlight, and red light combo would have been way more useful. Besides, I prefer the angle-adjustment bracket on all the other lights.
The Flare has a wide, even beam pattern, meaning it has almost no throw. It is not useful beyond close-medium range. It also has the worst coloration of the bunch, very blueish.
USER INTERFACE
All of these are good, none are great.
The Bindi is my favorite - a single press from off turns the light on. Each consecutive press cycles L > M > H > Off. Alternatively, if you turn it on to your desired mode and wait a few seconds, it will just turn off at the next press. Pressing and holding switched between Red and White light (red can be activated from off). Overall it does everything I need without issue.
The best aspect is the fact that it always starts low and ramps high. This is always what I prefer, as I hate being blinded by a high mode at night when my eyes have been dark-adapted.
The NU25 has two buttons, Power and Mode. Holding the power button turns it on, and each press cycles L > M > H (H only on the mode with both channels). It does not have mode memory.
Pressing the Mode button cycles between Flood+Throw > Throw > Flood > Red. It does not have mode memory for this either, so turning it off and then on will revert to Flood+Throw (annoying).
It also always starts on low which is nice, though the low is rather bright in my opinion, I would rather they cut the medium in half and give us a lower low. A double-tap of the power button from off gives us ultralow on the flood channel… but it’s still 7 lumens. Pressing the mode button from off activates red light, which is great.
The Deploy also has a power and mode button. Pressing and holding them together locks/unlocks the light.
Pressing the power button turns the light on to whatever output level was last used. Holding the button while on Jumps to the max output, and then ramps the light High > Low > High and back and forth however long you hold the button, blinking at each end. If you accidentally start ramping up from low, you will have to ramp all the way back to high to get back down again.
It works fine, I just wish it went in reverse, ramping from Low > High instead.
Pressing the mode button cycles between the variable angles.
The Flare has the simplest UI. Twist the red aluminum ring through the modes marked on the side: RED > Blinking RED > L > H > SOS. Very easy, though requires two hands when it’s on your head.
CHARGING
Both the Deploy and the NU25 UL feature well-sealed USB C charging ports, and multi-LED battery indicators. The Deploy’s port cover seems more reliable than the Nitecores.
Petzl stuck a MicroUSB in the Bindi and didn’t cover it up. Though this port is much more solid than usual, it’s nonetheless a notoriously fragile and unreliable port, and the lack of weather sealing really sucks. The secondary LED isn’t just a red emitter, but also a battery indicator. Pretty neat.
The Flare is quite different, it uses disposable lithium primary buttons cells (2032), underneath a small cover that was very difficult to get off the first time. This is not meant for regular usage, and I would strongly recommend against anything but its advertised usage as a stowaway backup/emergency flashlight (for which I honestly think it’s a solid option).
COMFORT
The NU25 UL, Bindi, and Flare all use the same shock-cord style headband. Extremely minimal, easily tangled, and includes retroreflective accents all throughout. As a bonus, the one on the Nitecore also glows in the dark!
I find all equally comfortable - they’re so lightweight I basically just don’t notice them on my head. The Nitecore’s double strap system is a little more finicky to adjust and gets tangled the most easily, while the Petzl system is the easiest to use imo.
Black Diamond’s Deploy again falls last for me. Though it’s probably more secure, I just find the wing system to be kind of uncomfortable as it forces the light into my forehead. It’s also much bulkier to pack - but is light enough that I can still forget about it relatively quickly. The retroreflective accents are not nearly as effective as the other three.
CONCLUSIONS
The Petzl Bindi has my favorite design of the bunch, very simple and minimal yet effective. At 35g, it’s the lightest (non-emergency) headlamp of the bunch and is great all-around.
However, the USB port is a major downside for me, and the price is simply too high in my opinion. The Nitecore NU25 offers the fullest suite of features, the highest output + best performance, and is the cheapest. It’s basically the no-brainer winner of the bunch.
I don’t care for the Deploy, it does nothing better than the other two in my opinion, other than look cool. It’s also the most expensive. I guess it does seem like the most well-built of the bunch, so I’ll give it that, and if you want smooth ramping than this does have it. It’s still a good light in its own right though.
Finally, the Flare is really neat, but has a relatively narrow use-case. For that “stash-light” usage, it’s great, being extremely small and packable, and weighing basically nothing. Lithium primary cells have incredible shelf-life and can withstand extreme high and low temperatures, so you would be able to count on this even if it’s been stowed away for many years. On the flip side, its performance is abysmal in comparison to the others…
IS ULTRALIGHT WORTH IT?
I am used to much larger and heavier headlamps. For the sake of comparison, I also picked up the Black Diamond Astro 300 and the matching BD1500 lithium-ion rechargeable battery,
- Astro 300: 42 grams (w/out batteries), $20 (I got it on sale for $13)
- BD1500: 27.5 grams, $30 ($23 on sale)
The Astro is a 3*AAA dual-fuel light, and comes with three duracell alkalines. I have a video on this topic coming up, but in short, Alkalines are garbage and should never be used - use NiMH instead:
As you can see, the BD1500 battery performs the best, but I think $30 is an absurd asking price. It comes with a small charger, which has a microUSB port. I hope I’ve made clear how much I hate microUSB. If it seems odd that output is lower with the li-ion, it’s because of its 3.7V nominal voltage vs the 4.5v from three AAAs.
As a AAA light though, it’s quite solid. Comfortable, and has the same interface as the Deploy (minus the angle-switching, but there is a version with a red emitter). There are a bunch of very similar lights from BD with various featuresets of course.
With this light, we are getting higher output and much longer runtimes than the UL options.
OUTPUT:
- Alkaline: 688
- NiMH: 661
- BD1500: 607
On paper, I might think that the Astro 300 and similar lights would be a better option: longer runtimes, higher output, more solid construction, and about double the weight, which doesn’t seem too bad. After actually using these however, I really do think the weight savings of the UL lamps makes a huge difference, in both comfort on-head and of course, as a means of shaving some unnecessary pack weight. Especially considering the NU25 is $37 (and as I understand it, the Bindi is much cheaper for those in Europe), I think these UL options are just superior.
On the other hand, if you need something highly durable and/or with superior performance, I would go with something like the Armytek Wizard series, the Skilhunt H series, or something from Zebralight. Significantly better performance than anything mentioned above, way better beams available (choice of high-CRI and warmer emitters), better UIs, and extremely durable.
THE END
Thanks for reading
I put this together to provide information to the community. I linked the video itself above, within its description are Amazon affiliate links to everything I tested (I don’t have incentive to sell any particular light to you, again I bought all of these myself).
If you have any questions, please let me know!
