You can see the emitter substrate in the middle reflector. I see white, not green. Looks legit. If the driver turns out to be any good I might get one, I have yet to buy a SRK.
I have one. its an XM-L2. got it for the same price. Its cheaper to buy these lights to get the emitters and stars (and other parts) for other projects than it is to buy the XM-L2 emitter & stars seperately from most suppliers. there is a 7-XM-L2 version too for around 45 bucks i seen somewhere.
I bought one from fast tech… my advise is… save your money as it is not as bright as regular SRK with 3 toroids driver
better yet if you like the compactness of this can light… go for SupFire M6 as it is brighter and easier to mod with simple resistor mod
or could just buy TR-J18 ($45) and you’ll be happy enough even with the stock will gives plenty lumens to satisfy your lumens lust
couple it with beast driver from lightmalls and you’ll be happy for awhile… just don’t use it on HIGH for more than 10 mins :~
So it not brighter than a regular SRK then it must be not brighter than my Fandyfire Warrior you’re right might just save the money for my next in queue the SolarStorm SP03 :bigsmile:
The output isn't a big deal, it's pretty easy to get more light out of it. The bigger problem is that the reflector isn't very good. It can be improved from stock a little by fine-tuning the focus, but it still puts out a horrible, ugly beam. No way to fix that unless you can find a compatible replacement 6x reflector... the normal 3x versions are easier to tweak and still get a really nice beam profile out of.
Yes, it shouldn't be surprising that six LEDs will put out more light than the same light with fewer LEDs, especially when modified. But will you want to use it after it's done if it has a hotspot with more rings than a XR-E C8?
Hmmm what the best one on the market right now? I am looking for one of these beasts but they have so much leds, that is getting quite excessive and reminds me of those dollarmart 20leds in 1 flashlights.
