If you say it is I am not going to argue. It would be a lot easier to do MK 2 in the first place and just bypass MK 1.
It would certainly have saved me the time I spent ruining the MkII tube. Iāve brazed and threaded 3 tubes now and wasted yet another day on the stop. With all thatās left to do these set backs are frustrating. the 2 lb single jack I mean shower floor really did a number on MkII but it was a necessary catharsis.
Rufus, you make me tired just looking at all the work!!! :person_facepalming: Tenacious would not cover your attitude toward making a light.
Iāll just sit here and try to recover slowly until the next highly anticipated update. !!! TL
I hope this isnāt a let down then. To make the stop collar I squared up a tube end on some sandpaper. And brazed it to a brass disc. Here it is next to the battery tube. Sooner or later Iāll need to cut some threads on the copper pill stock I brazed up way back when. Some of it will be used for the emitter pill and some for the tail cap. To hold the stock while I crank the die I brazed up this piece that I can solder the stock to. Next
Good luck.
34 days left, I might still make it.
Keep at it mate.
Make it or make it? I reckon youāll do both.
Keep going Rufus! I figure next you will be refining your own brass / copper from ore!! I am changing your name to ToughRufus!!
Looking forward to the next update. TL
Having trouble with pics. Those will be part of the switch set up. The following are the making of a lip on one piece and a shelf for the switch to rest on.
I think I exceeded the post length and the pics wouldnāt laid. To continue with yet more. Here is the sequence on the copper pill stock. The biggest one is the pill, the medium one goes in the tail cap, and the thin one is the driver retainer.
Led pill
I love that die stock. :+1:
Wow! Good work!
Understatement of the year?
Itās guys like RBD and MRsDNF and CRX (and several others) who make the BLF contest interesting to watch every year. The attention to detail is outrageous!
+1
Incredible craftsmanship and artistry in this build.
Thanks guys. Compared to what Hoop can do this is really low grade work, the threads feel like they have teeth they are so rough, similar to pipe thread from the hardware store. I might try dressing the leading edges of the cutting teeth at some point. Hand work isnāt supposed to be clean and precise but itās irritating to fall short of expectations. that probably shows a lack of humility but I get paid to worry over details and unlike my professional jobs the more I work on these parts the uglier they get. That being the case Iāll just have to avoid over working the finished assemblies. The problem is that to imitate what can be done on a lathe I have to build up layer upon layer, each one adding brazing alloy and requiring filing/sanding to fit the next one. The two button pieces were thin sheet brass formed to the same curve as the battery tube with nesting tubing sanded to the same curve before cutting ~5 mm off to braze. In all, there are nine separate pieces of brass to make the thumb switch module and eight more(including two of copper) in the tail cap. When itās all done Iāll count up all the rest but ābucket Of partsā was a pretty apt description. I seem to use the drill press enough that I should change my screen name to MrSdp but thereās a lot more time hand working small parts or sanding things ~round /~square.
Rufus,
Copper + a Die shouldnāt = threads anyway!! That is like threading bubble gum with a golf club. You did danged good. I like the way you used the die as a holding jig!!! I would never EVER have thought of that.
On that copper a scotch brite pad and your drill press will smooth those threads some. I call them āScrubbiesā in my shop. If you donāt have one, PM me your mailing address and Iāll mail you a couple. They are good for a lot of things. I sure enjoy seeing your efforts and ingenuity. Thank you for the effort it takes to show us all that work. :+1:
TL
Thanks, we have them and Iāll try it. If it works on Revere Ware then why not? For the record, thatās an 18ā pipe wrench I used to tee off.
As well as Scotch Brite I remember OL (at least I seem to remember) using steel wool, the fine stuff for cleaning up threads. I agree with you RBD about Hoop. What he does with copper is a work of art but yours is also just worked in opposite ways. :+1:
I think the steel wool is goodā¦ but rememberā¦. if it is a copper part that you are going to patina, donāt use the steel wool. Boy did I get in trouble with that one time!! Whew! I did a copper light for a customer and he wanted a patina on the copperā¦ an ugly green mess in my opinionā¦. but I had used some steel wool for a fine satin look first. I have always thought the steel left a coating of some kind on the copperā¦ the patina was blotchy and a real mess. Even after being in a sonic cleaner and then steam cleaned. When I re-finished the copper with a scrubbie, the problem went away. That only cost me a full day!! :confounded:
TL
