6.1A only - Sofirn 18650 3000mAh
Oh dear, the Sofirn 3000mAh 18650 is only rated at 6.1A. No wonder the Q8 Pro only achieves roughly 8K lumens and almost 2X with Samsung 30Q’s. (Tactical_Grizzly’s measurement, and that 8K is at the very start, not ANSI)
I’m currently reviewing the D25LR and thought I’d make a battery review to go with it. The BAK N18650CK is only rated for 6.1A, and no idea if that’s a continuous rating, the datasheet just says Max Discharge Rating.
These are perfectly fine in the lower lumen models, but for everything else I would advise against it.
Sorry Sofirn, but you need to source some decent cells with at least a 10A continuous discharge rating. We’d happily pay extra for cells that perform at your flashlight’s rated output.
That does explain it. I second the notion of Sofirn including better 18650’s. LT1 should come with 3500mah, and Q8 Pro should come with 10-15A rated.
I was measuring 5 different capacity and brand batteries earlier today in a high lumen light and a 1-year-old sofirn 3000mah battery wouldn’t quite get to 6 amps. I expected it to be the worst of that bunch amp wise and it was. I have at least five other brands and capacities that I’ll do in the near future. I’ve got to rig up something different to measure voltage drop but I know they don’t do real well in the cold.
I’ll post some pics later, but the spot welding job the factory is doing is rubbish, this would reduce performance even further. They used a too high setting and blew straight through the top cap, I popped it off with a knife easily.
I’ll run the discharge tests without the button or perhaps I should spot weld on a new cap
I thought this was already a well known fact?
They change cells all the time, but it used to be a 10A cell. This one isn’t much better than the ncr18650b
I think they’ve been using the 6A 3000mAh DLG battery for nearly 2 years.
Nah, the DLG cell they were using had INR18650 written on it and it tested very good at 10A. I have the DLG 6.4A and this is much worse performance
Sofirn’s current 18650 batteries are still listed as 6.4 amps continuous drain, basically unchanged from three years ago. I just received their SD01 dive light that includes 4 of them. Considering that this is a 10,000 lumens claimed light and the Nitecore TM28, a 6000 lumens light, lists 10 amp CDR batteries as necessary for maximum performance, I suspect the Sofern is battery limited for maximum performance. This is pretty much verified by post 1 here. I guess that I will be investing on a set of 15 amp or higher rated 18650 button top batteries for it.
Still better than Fenix cells. The cell that come with me Fenix E28 is rated at 4.5A and 3400mAh capacity, not a year and half later it’s down to 2600mAh and I’m not even using it much. Total trash. Tore the wrap off and it’s a Noname cell.
That’s why I only use Sofirn cells in low drain lights, like my Convoys with a 3A or 5A driver.
They’re such great value though that I always choose Sofirn lights that come with these cells where possible.
I wonder if they have updated them as of recent. I don’t think the cells are too bad especially considering i got 4 for free with the Q8 pro i ordered on sale for 30$ lol. It wasn’t even supposed to come with batteries but came with them anyway. I’m still going to get some sony VT4’s for my Q8 pro though I’m sure it’ll preform much better with those :slight_smile:
I wonder if anybody’s unwrapped these cells and if so i would be interested in what’s under the wrapper.
