Does anyone who owns a SRK think it’s possible to cut and thread the bottom of one an screw a second one in. Making a 8x 18650 host. Just so people don’t think I’m crazy, configuration will be 4s2p not 8s.
Also, the cheapest I could a 4 18650 light is $34 shipped. Is there a cheaper source. Empty host would be ideal but I don’t think it’s possible.
Curious as to why, its already hard to hold on to on high after 15mins due to heat, double battery number and size will just make it that much harder to hold, and “fins” of the two bodies would be difficult to have line up.
sorry to sound pedantic, but would it not be 4P2S? so 8.4v output?
in some respects I think that’d be good from a driver point of view but you now have me wondering what your up too since the heads wont be used at all.
could you not machine a single billet to give the same result? I guess it depends on the cost of a length of thick wall tube and your ability tools wise to line bore it to suit.
Not too sure what pedantic means. I’m also not sure how a srk has the batteries. Is it 4P? I would have to get creative with the wiring but 4s2p is what I’m after. As for machining an entire new body the thought crossed my mind. I have a lathe an any lathe work can be done at home, but the milling/deep drilling I would have to take to my work an do, and I hate doing personal jobs there. Even then for $66 I could join 2 bodies together and have something that would have a nice finish and look prettier and be alot quicker to do.
If you’re looking to join two bodies together only, all you need to do is to machine a short piece of tube with proper tap on the inside to screw both bodies together. You do have a lathe, don’t you?
Your right, no argument but some people cant stay away from heartburn.
Theres nothing like spending days turning something worth 2 bob into something worth a dollar having spent $200.00 on it on parts alone. Well I usually do and I dont think I’m alone. There must be a thrill somewhere.
Took a while too rough seeing I didn’t have any pipe or round stock for that matter. Threads are 24 TPI, a thread depth of only .022” it cuts pretty quick. With a 2D for size reference. The outside diameter is 2.100” same was the tail cap.
