A bicycle light by Sofirn
Thanks :slight_smile: . I really want to see future updates of that your bike light project.
I’ll be testing out my Sofirn IF25a this coming year.
I ride mostly road and gravel trails.
I think the “Bike Flash” mode present in Convoy lights will be a good feature to have for any bike light. It is really useful for grabbing attention on the road and also helps with runtimes and heat management.
Absolutely. I have dedicated flashers and bike specific lights but I wanted to test out this one and my S2+ as a bar light.
Something similar to Lumintop B01’s form factor (looks like regular cylindrical flashlight) and beamshot (good cut off), but on steroids.
Brighter Turbo and higher sustained output, constant current driver, 3000-4000K CCT, Sofirn’s own UI.
My 2 cents.
Problem with IF25A is that it have low sustained output for MTB but I think for road it will be ok. Now I collect several bike lights. New one Astrolux BL06 it is interesting. So far my self containing favorite bike light still my old Fenix BC30. This year I also bought Magicshine RN3000. It is very powerful but lack in output stabilization. Output go lower with batteries go low. RN3000 have very good fast charge with PD of about 24W and power bank function of about 18W. Old Fenix have better LED driver compared to RN3000. By the way Fenix made great bike lights. But in 2022 they remain a little weak with only about 1200 lumens compared to another brands. Also Fenix have best bike mount system for me.
Specifications have been ratified, final product was 5000 lumens rather than 8000 lumens - probably too much heat generated at the higher end.
I find there is a lot of energy lost from heat when pushing 2000+ lumens out of the 3 white emitters.
What are the final LED emitters used? What about XHP70.3 HI or XPH70.2. Thats are most effective emitters on market which generate less heat. Most important it is to have better cooling on LED for higher sustained output. I have friend which own Monteer 8000 which is similar to your light design. But 8000 lumens are just for “WOW” effect. If your light have efiicient driver and good thermal case design I thinks it is possible to be better product compared to 8000. Can you tell us more about manufacturer of this light. It is very similar on package to Astrolux BL02, BL03, BL06. Also I saw that mount is the same as Astrolux lights.
I’d also suggest to create a light with cut-off beam by using CAD-aided reflector or lens optics.
With a bright taillight you know the direction of a bike.
But the use of standard plugs like USB-C instead of proprietary cables.
New to BLF and to this thread, wondering if this project is still alive, but nevertheless, would like to add my view on the topic, because I’ve been a relatively budget aware bicycle lights enthusiast for years, having bicycle lights on basically at all times for my own and others safety and also to see in the dark whether it’s riding on country roads or off-roading on trails.
My thesis is that bicycle lights should cover pretty much the same basics as standard, road legal motor vehicle lights, only smaller in size and lighter in weight. What I mean with the lights basics is that there needs to be different functions and different kind of beams of the light for different occasions, not just one beam with various levels of brightness. Constant flashing let alone different colors than white (which can be of different color temperatures, make no mistake) are a total no-no. Rear lights are not that much of an issue, they just need to be steady and bright enough to show your location, which is easily achieved because red LEDs show very well even at very low sub 1 Watt power levels, a little brighter brake light with motion sensor is ok too, but rear lights are really not a problem anymore, you can buy them from supermarkets, they cost next to nothing and you’re fine with them. Other lights, like extra safety lights visible from the side are not necessary at all, orange or white retro reflecting ‘cat-eyes’ cover that need for visibility in darkness more than well, active safety from passive technology, so to say.
First and what is probably needed the most in running hours would be a daylight running light, it has only one requirement, to be bright enough in daylight to be visible to others, something like 100-200lumens of omni-directional flood light, not too much dazzling, but bright enough to be seen from reasonable distance in daylight. The daylight running light should probably have two or three different brightness levels, that could be automatically switching via sensor due to ambient brightness, less brightness in dull, grey day and more brightness for the bright sunny day and optionally an extra low brightness mode for the dusk, where you still don’t need light to see where you’re going, but ambient lighting getting lower the less brightness is needed to be seen by others. Possibility to manually flash the daylight running light at higher brightness to gain momentary extra attention would be desirable, but not necessary, if the light has high-beam mode that can used for that.
Second, there needs to be low-beam, often referred to as StVZO, cut-off beam etc. Anybody with a driver’s license and motor vehicle driving experience knows the concept of low-beam, it’s a light beam that is optically suppressed from emitting too much light above certain horizontal line to save oncoming traffic from getting dazzled to provide safety in traffic. Unfortunately the LEDs got very bright in very short period of time and they were applied to cheap bicycle lights willy nilly without thinking, that bright LEDs with small surface area are very much dazzling to others even at low levels of sub 100 lumens or so, let alone several hundreds of 1000+. This has been fortunately solved partially by German and French legislators that have not been sleeping on it (Netherlands has some legislation also, maybe elsewhere too, but not globally yet) and have created standards that take the beam shape into account for bicycle lights above certain levels of brightness, which is why we bicycle light enthusiasts have even a possibility to be responsible and not dazzle the others by choice.
Third, there needs to be adequate high-beam equivalent light mode too and preferably not only one kind of beam, but at least two. Bicycle riding in darkness requires high-beam option like any other riding or driving to be able to see properly as needed. The high brightness is less of a requirement, than the optics to direct the beams in useful ways specific for bike riding. On road bike you may ride on empty roads at relatively high speeds, which means that you need to see a realitvely long distance ahead of you to be able to detect the road and any possible obstacles or changes in the road so that you have time to react in order to dodge, slow down or even stop, hence you need more or less of a spot light beam not extreme and preferably not fully round circular, but somewhat oval, that can show a little bit of the sides, while shedding the light straight ahead with a decent throw. But there are other use cases for high-beam equivalent bicycle headlight too, those cases you’re riding slower on poorer roads, gravel, trails, cross country even, you want to see well, but you don’t need so much throw, though some is okay, as you need to see your surroundings and be able to detect winding corners, steep ups and downs at short distance. Hence you need something like an ovalesque mix of semi-spot and semi-flood for that. This feature would be cool, if the light had a speed sensor similar to a bike computer for example that would enable automatic change of beam type according to the speed, so when riding fast the light would dim the semi-flood and brighten the spot and again when going slower the spot would dim and semi-flood would be brightened. High beam should also have a manual flashing made easy so that you could flash them as needed for extra attention, just like you would driving a car.
Other things to be taken into account. External batteries are a must, they enable scaling the amount of watt hours you might need for your rides. 12V system is preferable aka 3 in series (3S) lithium-ion battery packs, 3 cell, 6 cell, 9 cell, even 12 cell for longer rides at night. Higher voltage is generally better, because it means less amps, hence puts less strain on the components. It’s also better to use more LEDs and pump out insane lumens out of them to save the light from the heat, I think 50% of the LEDs maximum lumens is quite enough, despite it increases the amount of LEDs needed to get higher brightness, but like said, huge brightness is not as important as proper optical direction of the beam. I would say for daylight running light 100-200lumens of omni-directional, hemispherical beam is more than enough and for that there can be as many LEDs as needed, from top of my head I’d say 10 fairly low power LEDs would be quite ok. For low beam, adequate amount of lumens would be something like 400-600lm with for example 100lm per LED or so 4-6 LEDs in total, small in size and precise in beam, beam optimally optically directed so that the light is where the cyclist needs it the most, on the road, mostly forward straight ahead, fading smoothly to the sides to cover adequate width of any regular roads while catching the sides and corners within a reasonable distance, whihc doens’'t have to be too far. For high-beam there could something like 2000-400 lumens, that could be manually adjustable within range from 500lm to 4000lm, so that if you don’t need that much light, you could ave some battery, and if you need all the brightness there is to put out, you could blast it on as you wish.
All in all, bicycle lights are a special kind of vehicles lights, they should conform to any legal vehicle lighting concepts, but with the great difference that they need to be reasonably light in weight, including the light unit and its power source. There’s a challenge to meet indeed, but I’m sure it’s not impossible to achieve, though it may require taking shortcuts on the way and not all goals are achievable in their full glory, yet the concept and goal must be ambitious and not dilute it with too many compromises to make the end product seem like it was designed by commission.
Lights that I wish people would study as examples of interesting implementations of vehicle lighting concepts in bicycle world are: Supernova M99 series, the Pro versions aka ones with low-beam, high-beam functionality. Supernova is the leading manufacturer in implementing the low-beam and high-beam in their lights. Other interesting ones are B+M IQ-XL, also a low-beam, high-beam light made for e-bikes, but if you know how, you can make them work with an external battery without an e-bike as well, not a problem. There’s also Herrmans Nordic Extreme 12V e-bike light that has low-beam, high-beam functionality. Other lights of interest, which unfortunately lack the low-beam, but have interesting concepts neverthless are K-Lite Ultra, a dynamo powered high brightness “adventure light”. There are also a plenty of cut-off beam lights be it battery, e-bike or dynamo powered that have no high-beam and equally great numbers of off-road lights, basically all a little higher brightness, say ~500lm or more can be counted in, that can serve well in darkness but are totally a nuisance to others in any oncoming traffic.
Links:
  • Supernova’s high-end battery operated bicycle light: M99 Mini Pro B54
  • Supernova has also similar dynamo operated M99 version: M99 DY Pro
  • Busch+Muller’s giant low-/high-beam e-bike model: IQ-XL High Beam
  • Herrmans only model with high beam that I know of: Nordic Xtreme
  • k-Lite dynamo light without low-beam, but interesting: k-Lite Ultra v2
  • Crown funding started maker of interesting bicycle lights: Outbound
  • Compact high power lights with interchangeable optics: Gloworm
  • Sigma’s 2000lm off-road classic w/ quality optics: Buster HL2000
  • My favorite basic cut-off beam dynamo light: Herrmans MR-8
Of these examples what I would like to see as a BLF cost effective competitor and equivalent in functionality would definitely be Supernova M99 B54 Pro, it has almost all I can hope for, compact light unit, low-beam high-beam with wired remote switch, 12V aka 3S battery, different brightness modes to choose from. What I don’t like about Supernova M99 B54 Mini Pro is price, obviously, though it’s justifiable, because Supernova’s build quality is pretty high in the world of bicycle lights and guarantees are long for a reason, they do trust their product, but the price is a bit hefty for a bike light nevertheless. Another thing is their matrix optics, which is far from perfect.
I have myself M99 Mini Pro 25, an e-bike version with external 12V voltage regulated custom battery on a normal bike and despite I adore the low-beam high-beam functionality, the beam is a bit too wide, lacking central bias and due to the matrix reflector there’s a kind of a checkered pattern in the projected beam which is disturbing to the eye when riding in darkness. Another annoying thing, common to all above listed high-beam capable lights is, that they work a little different from motor vehicle lights in a sense that low-beam is constantly on, aka when you switch to the high-beam, the low beam stays on lighting the foreground too much and the high beam seems weak on top of that, but will of course shed light a bit further, only that the difference to the low-beam isn’t that big because of too much light in the foreground. One thing that I would like to see different in the implementation of the high-beam is that the low beam would be turned off and the high beam would be double or triple the lumens of low-beam to make real difference.
If there are any other who done their home work about bike lights and probably road legal vehicle lights in general, please feel free to have some input. Or if you’re someone who hasn’t studied bicycle or vehicle lights in general, but are curious and interested in lighting bicycles, please help yourself and study these examples listed above, of lights that represent somewhat the leading edge of the bicycle lighting today. There are others too, some similar, some more expensive, some higher brightness, some more exclusive etc. etc. I just didn’t want to make too long of a list for starters, just focus on the main concept that I think bicycle lights should be made conform to.
TL;DR? Guess my motto for bicycle lights would probably be something like:
“A proper bicycle light has exactly the same requirements as any other road legal vehicle lights, only in flashlight equivalent scale, if not even lighter in weight.”
EDIT: Forgot to add that a dynamo hub powered backup low-beam functionality would be useful if not even mandatory for those times that the batteries simply run out of charge and you’re in the middle of nowhere in pitch black darkness in desperate need to find your way. Dynamo hub could and probably should be also power source for the daylight running light, so you’ll save max. battery runtime for actual need for the dark hours. Dynamo hub should be always used in conjunction with the battery operated lights, just because the dynamo power never runs out of charge, where again batteries can offer higher power normally for seeing in the dark, hence they cannot be held mutually exclusive in anyways. Dynamo hub can even be used to charge the batteries in the worst case scenario, if there are no other sources available during the day.
I would be very interested in a bicycle light from Sofirn. Just wondering if anyone else would be as well. Give what I have seen so far in regards to their price to performance ratio you can’t go wrong.
Agree, I have only one decent flashlight yet, Sofirn SP36 BLF, 5650lm and I like it very much. Sofirn seems to be very decent maker and would easily compete with Magischine and likes, especially in off-road bike lights category.
My wishlist would include:
Powered by a 21700 cell. Although the ability to also use 18650’s with a spacer would be fantastic.
Anduril of course
A couple options in the way of color temp
Floody with throw
The mount would need to be robust with very good adjustability
Waterproof/Shockproof
Please feel free to add to the list.
If we’re talking about serious bike lights, there needs to be an external battery pack version, which could exist alongside with an integral battery model. Problems with integral batteries is the weight, you can’t have that much battery capacity on handlebar with a simple clamp mount, it’s not convenient nor safe, hence external battery pack is always a better choice. External battery pack allows also scaling the watt/amp hours to your need by having a pack with number of cells you need.
Anduril is not very good UI for a bicycle light, simply too much options managed via a single button. Bicycle light needs pretty straightforward, carefully chosen and limited number of actions and even then a wired remote control button is more than desirable so you can operate the light with your hands on the handlebar at all times preferably. Of course more than one button would be perfect, one for each main category of use, two buttons for setting brightness up and down, not just rotate one direction, flashing mode selection perhaps also ideally two buttons, special modes selection also with two buttons. And there could be one button simply for manual signalling, press and and it will flash the light three times or press contantly, it will keep flashing until you release.
Color temperature should be able to choose from at least warm ~3000K, neutral ~4000K and perhaps cool ~5000K, personally would prefer warmer, because red wave lengths have better penetration at lower lumnes, whereas neutral or cool will seem bright, but will not show any better. CRI should preferably be relatively high, above 80 at least.
The beam, if we talk about an off-road light, should have different levels of depths that it can handle and most important, the beam must be more or less ovalesque, something like 2:1 ratio would be good, say ~30° wide and ~15° tall with a decent hot spot in the center and nice smooth fade out to dim on the edges.
Personally I think there should be a light, that has two off-road lamps, one with semi-flood to to semi-spot optics and another with semi-spot to spot optics and there should be also a third light for motor vehicles low-beam equivalent cut-off beam to have light that is road legal everywhere.
Mount has to be good indeed in correlation to the light unit weight, where external batteries come in handy, because the handlebar which is the natural mounting point for the light, shouldn’t be burdened with heavy batteries, but a light weight light unit only and the batteries are better mounted on the frame, either the top tube or the diagonal down tube. Battery pack could be two parted, where there would be the batteries and a holster that would enable rapid mounting and removing of the actual batteries from the bike, while the holster remains on the bike.
Weather, water and shock proofing are absolutely mandatory, that’s given, but with weight kept in mind, meaning that the light can’t weigh any more than absolutely necessary to be shock resistant and be able to dissipate the heat from LEDs at higher brightnesses.
The list of ideas would go on and on and I’ve written down most of mine in my previous reply, but felt need to address the original post directly too.
Main aspects to take into account when thinking of designing a bicycle light are:
  • Power source and its specs, Li-Ion batteries are a non-brainer, voltage, 3,7V or 1S is low and needs amperage, 7,5V or 2S is commonly used, but I’d think 11.1V or 3S would be better, even 16V or 4S if applicable, the higher voltage, the lower the amperage which puts less strain on the components. Dynamo hub is a great power source, never runs out of charge and lights can be engineered to pump out a good deal of lumens out of dynamos with LEDs. Batteries provide plenty of power for use at once, dynamo provides more limited amount of power, but lasts as long as the front hub keeps rolling. Clever use of both battery and dynamo for powering the lights would be the best solution.
  • Optics and it’s use cases, cut-off or low-beam for the traffic among other goers and lighted areas, usable also as daylight running light. Different levels of oval off-road beams separately and overlapping each other some, either always on at the same time or even usable separately for different occasions.
  • Weight and it’s distribution, integrated batteries are fine for small urban lights that you can mount and dismount as needed, but you can’t have a lot batteries mounted on your handlebar, so if you need more for higher brightness lights you need external battery packs for that, which will allow a separate light unit that will weight not that much on the handlebar, while the frame can carry the battery weight.
Lupine Lighting is the competitor of Supernova, like AMD/Intel or Apple/Huawei.
https://www.lupine.de/products/bike-lights/road-bike-lights
Other manufacturers of high-beam bicycle lights are:
https://www.cube.eu/de-de/acid-e-bike-frontlicht-pro-e-140-high-beam-bes3/93812
https://www.cube.eu/de-de/acid-e-bike-frontlicht-pro-e-140-high-beam-bes2/93149
MonkeyLlink PowerBeam Light 280 Lux Connect
Trelock LS 930-HB LIGHTHAMMER
https://www.trelock.de/de/licht/beleuchtung/e-bike-beleuchtung/e-bike-frontscheinwerfer/ls-930-hb-lighthammer
Thank you for the links angerdan!
Most of these models I have come across before, but somehow they haven’t caught my attention so much, hence will have to take a better look.
Lupine I’ve been well aware of, but never took their product seriously them being such exclusively priced, as my limit for a decent lamp goes at around 300€ per unit or if the light is somehow exceptionally spectacular then I might stretch to x1,5 or so above that, but beyond that price point my interest is from very low to non-existent. Reasonable price for a decent lamp with good build quality and adequate functionality is around 250€.
One thing that I don’t much prefer of the bicycle lights marketing is too spare use of actual beam shots, I think B+M and Herrmans are the best in that, being honest about their product in the sense, that they provide at least some beam shots, when the beam actually is the key element of any vehicle light or lamp, not the looks or design of the lamp unit itself. Some beam shots can be found from youtube, but not always for all models.
Anyway, my idea of a budget version of LB/HB bicycle headlight would be a unit, which I already somewhat described earlier, that there would be three lamps in one, one lamp for LB and two for HB, spot and semi-flood, each with their own optics, using either TIR lenses or reflectors. And if necessary the HB spot and semi-flood lights can be squeezed into one with proper optics, so two lamps in one is a bare minimum, all you need is an accurate and responsive switch between the LB/HB to make the use reliable. You can have now two separate lamps, a plain StVZO LB and an off-road light for the HB, but there’s no switch between and operating off-road lights can be tricky, if they have delay in the on/off functionality, like they often so, 2-3s, continuous press, which must be precise, which can be hard while riding on uneven terrain steering with one hand, for example.
Hope the discussion about a possible BLF bike light continues!
Absolutely love the HS20. It’s my nightly “take the dog out” Headlight. Double the SFT40 + LH351D LED, and you would have a winner! So impressed by the throw of the SFT40.
What is so special about sofirn? from what i see on their websites their lights are copies of other brands and off brand lights, some with minor changes. So if you want a bike light from them, you’ll have to wait till they copy someone’s else successful design.
I use D10 with anduril driver in custom printed holder on my bike, as well as a headlamp, i love bike storbe function of anduril, i do realize anduril maybe too complex for some, so maybe a simpler UI would be better, but bike strobe, imo, needs to be included with another UI,
They have produced BLF lights before, so maybe they’re a co-operative company in such projects? I have Sofirn SP36 BLF and having my eye on their Q8, though my bicycle light purchases tend to supersede flashlights, so I don’t know when that’ll be happening. I tried printed holder for my SP36, but at almot 500g it’s way too heavy, affects steering and Anduril UI is far too tricky to handle when riding, you must concentrate on riding rather than managing your flaslight’s plethora of single button click patterns.
Indeed what you about the strobe or any kind of constant flashing on a bike headlight, it’s a no-no and nobody should use these. Manually operated flashing for signalling purposes is fine, peer to flashing high-beam on motor vehicles, but constantly flashing light is too much attention seeking, can be mixed to turn signals and are generally confusing and annoying for others. I also wonder how people ride even in the dark with flashing on, would think that it interferes with their own perception pretty much too.
I use flashing mode during the daytime, where I ride there are many trees which create long tunnels of shadows along the roadway. In these situations the flashing headlamp does work to alert oncoming traffic of my presence. The shadows and people wearing dark sunglasses make it difficult to see a cyclist.
I could keep the light on in a steady state, but that decreases the runtime.
Currently I use the Lumintop C01 it is compact, inexpensive and adequate for this purpose.
Why is it a no no??? is there a regulation for that, or a law? as far as i know, neither exists. so no no is simply your opinion,
Actually riding in the city sharing roads with cars, you WANT as much attention as possible, i see others use strobes all the time, when i ride and drive a car, i do not get confused nor annoyed, nor distracted, i see a strobe, i know it is a bike or a scooter. it does not look like a turn signal, or anything else to me, only that a bike or a scooter is closing in. It will pass in a minute, and the strobe will no longer be visible. no reason to get “mixed” signals, nor get annoyed. If a bike with a strobe triggers that in you, it is not the strobe that is a problem, imo.
As far as riding at night with a strobe, well i agree here, not the best thing to do, that is why i like anduril’s bike strobe, it does not interfere with my perception. The bike strobe has constant brightness fo the strobe itself, but a steady light brightness can be adjusted, so you can make the strobe less or more noticeable, so you can adjust it if it interferes with your perception,
I understand the sentiment pro flashing bike lights, but generally object to use of them, because it doesn’t conform to vehicle lighting in general, it’s an alert and like said, too much attention seeking. That said, occasionally in winter time during the day when it’s not that bright and there’s a lot of traffic, I may resort to flashing light mode myself as well, but only occasionally and never alone, but in addition to another, steady light source. If everyone would use flashing lights it would be an idiotic situation, blinking all around confusing everyone. It’s also studied, that the flashing light mode makes it actually harder to detect a cyclist, because of the flashing makes it harder to follow the exact location of the cyclist, let alone there were a sea of flashing lights all around, all blinking out of sync from ech another, creating weird and confusing blink light patterns as a whole.
Limited battery runtime is one problem with lights that have integrated battery, the size and weight of the lamp compromises it. That’s why the light needs to have also lower brightness steady daylight running mode(s) that are projected so that the oncoming traffic can see you, but it doesn’t consume too much battery.
