The idea for this experiment was born from the necessity to find an alternative way to measure the current pulled by my quad emitter Convoy M2. When using my very very cheap multimeter, current on direct drive was reported as 6A, which seemed unlikely considering how quickly the light would get hot and how easily it ate through batteries :person_facepalming: . Another thing that made me think there was a problem was the fact that low voltage protection would trigger very easily when trying to take longer readings, hinting at the fact that the reason for the wrong readings may be the much too high electrical resistance of the the multimeter’s leads.
I don’t know if someone has come up with this idea already, so here I will explain the procedure I came up with as best I can in case someone else wants to try:
What is needed:
- a multimeter or some other way to measure battery resting voltage
- a stopwatch or some other way to measure time
- a glass of water, bigger is better
- accurate low current discharge curves for the battery you are using, I used these: lygte-info.dk/review/batteries2012/Samsung%20INR18650-30Q%203000mAh%20(Pink)%20UK.html
- the flashlight and a charged battery of course
Procedure:
- record resting battery voltage before putting it in the light (in my case it was 4.18V)
- put the light on turbo ad leave it underwater inside of the glass so it doesn’t get too hot during the measurement, at the same time start the stopwatch
- after the amount of time you want to sample has passed (I did 3:00), shut off the light and pull out the battery
- don’t record the voltage right after because if the battery has been discharged at high currents the voltage will climb back up over the following minutes. Take a reading every minute until the voltage stops climbing, then you can record it (3.98V for me).
- go watch the lowest current battery discharge curve (low current because although it doesn’t take into account the additional energy wasted as internal resistance of the battery, you are using resting voltages and this should be the curve most comparable to those) to get an idea of the Ah consumed:
this was the curve I looked at and I extrapolated about 0.63Ah of used capacity.
- then to get average current during the test, divide that by the duration, in my case the result was 0.63 Ah / 0.05 h = 12.6A
So this little beast is able to sustain quite a lot of power when kept cool enough, in my hands the battery tube becomes too hot in less than a minute though :laughing:
I’m glad it worked, it’s not as quick as using a multimeter directly but it’s a different method with some advantages and disadvantages. Those that I can think of are:
Advantages:
- this method gives you a measurement of the complete flashlight system, using a multimeter in place of the tailcap can result in measurement errors due to the multimeter having higher/lower resistance than the tailcap switch (as was my case).
- this method gives you a more useful / practical reading, as it is an average of the power during a certain period of the discharge as compared to an instant reading (you can do average readings with a multimeter but it’s difficult with high powered lights because they get very hot and you can’t just dunk them in water).
- it’s fun seeing how much your light can heat up the water
Disadvantages:
- because you are looking at a low current discharge curve for a relatively new battery, the power lost due to internal resistance is underestimated, even more so if you are using an old battery. I’d estimate the margin of error to be lower than 10% in my case, but this gets worse with higher discharge currents and weaker batteries
- it’s more work
If you decide to try this method out, let me know the results, please let me know if you find an error in my reasoning, and good luck to anybody trying this! ![]()
(if anyone wants to know, the light tested was an m2 host with kiriba’s quad copper spacer, 4 nichia 219c d320 on the mtn quad mcpcb, a carclo 10622 optic behind an ar coated glass from kaidomain, an mtn-17dd with 20awg positive wire and 18awg negative, tail spring bypassed with a 20awg, stock 1288 switch)
