A EDC flashlight in Titanium with high lumens.
Maeerxu XT4 21700 Battery Super Bright Titanium Flashlight
Waterproof: IPX 7
Max Performance: 4000 lumens
16 main lighting modes can be customized, with an arbitrary selection of memory mode.
The built-in thermal control module will automatically adjust the brightness to the temperature and battery status of the flashlight.
Store:Maeerxu XT4 21700 battery 4000 lumens super bright titanium LED flashlight - maeerxu
Ebay: maeerxu888 | eBay Stores
Aliexpress: Maeerxu Flashlight Store - Amazing products with exclusive discounts on AliExpress
Maeerxu XT3 in Titanium EDC Flashlight with luminous tubes.
It has 3500 lumens(max) and it has seven-color auxiliary lights.
Can be purchased together with luminous tubes
16 main lighting modes can be customized, with an arbitrary selection of memory on mode.
Store: https://www.maeerxu.net/product/maeerxu-xt3-anode-colored-titanium-18350-edc-flashlight/
eBay: maeerxu888 | eBay Stores
Maeerxu XT3 Brass 18350 3000LM EDC Flashlight
Lamp bead type: 3 * XPL HI / 3 * SS-T20 / 3 * 519A.
All gear can be saved by any selection.
New streaming lights have been added and the seven colour auxiliary lights have a memory save option.
Store: Maeerxu XT3 Brass 18350 3000LM EDC Flashlight - maeerxu
Maeerxu XT3-18350 Anode Colored Titanium- Golden Memories.
Light bead model: 3 * XPL HI / 3 * SS-T20 / 3 * 519A
Copper substrate: electrical separation of copper substrate, faster heat dissipation
Auxiliary light: Light the flashlight for the default seven color light show.
New flowing lights added.
Seven color auxiliary lights with memory save option.
Store: http://www.maeerxu.net/product/maeerxu-xt3-anode-colored-titanium-18350-edc-flashlight/
Maeerxu MT3 18350 Titanium Flashlight New Model 519A 3500 Lumen
It is very convenient to carry and can meet your daily requirements.
Copper base plate. Electrical and thermal separation copper base plate can make heat dissipation faster.
Auxiliary light: seven-color auxiliary light, new seven-color running light
Store:http://www.maeerxu.net/product/maeerxu-mt3-18350-titanium-flashlight-new-model-519a-3500-lumen/
AliExpress: https://www.aliexpress.com/item/1005004880524051.html?
Maeerxu DF01-21700- Titanium Four-Lamp Highest 4000 Lumen Flashlight
Max Lumens: 4000 lumens.
Lamp bead model: 4 * SS-T20 / 4 * XPL HI / 4*519A.
Low voltage prompt / reverse polarity protection / mode memory: Yes :check_mark:
Switch mode: Tail mechanical power-off reverse switch (Press. Turns on/off the flashlight. (Half press: switch gears and functions).
Dimmer mode: 16 main lighting modes can be customized, arbitrary selection of memory on mode.
Store: Maeerxu DF01-18650- Titanium Four-Lamp highest 4000 Lumen Flashlight - maeerxu
Maeerxu-DF02-Titanium 3000 Lumens(max) Mini Edc Flashlight.
Surface color: Titanium natural and titanium stone.
Lamp bead: 3 * SS-T20 / 3 * 519A
Dimmer mode: 16 main light modes, customizable. Arbitrary selection of memory on mode.
Store: http://www.maeerxu.net/product/maeerxu-df02-14500-16340-3000lumen-mini-edc-flashlight/
Ebay:maeerxu888 | eBay Stores
Aliexpress:Maeerxu Flashlight Store - Amazing products with exclusive discounts on AliExpress
Maeerxu DF01 in aluminium EDC Flashlight.
Low voltage prompt: :check_mark:
Reverse polarity protection: :check_mark:
Mode memory: :check_mark:
Copper base plate: Electrothermal separationcopper base plate can make the heat dissipation more fast.
Auxiliary light: After startup, it defaults to an auxiliary light that cycles through seven different colors.
Maeerxu DF03 in Red Copper EDC Flashlight.
Lamp Bead model : 3 * SS-T20 / 3 * XPL hi / 3 * 519a
Copper base plate :Electrothermal separationcopper base plate can make the heat dissipation more fast.
Built-in thermal control module will automatically adjust the brightness level according to temperature status of the flashlight.
Maeerxu DF03-Titanium-16340 EDC Flashlight
Maeerxu DF03 in Brass EDC Flashlight.
Maeerxu: How to operate our flashlight auxiliary light-Section 1.
Maeerxu DF02 in Aluminium.
Batteries Model: 14500 / 16340 ( Batteries not included in the package)
Lamp beads: 3 * SS-T20 / 3*XPL HI / 519A
Store: https://www.maeerxu.net/product/df03-titanium-16340-3xpl-hi/
Maeerxu DF01-18650 Titanium Anode Camouflage.
Do you guys love it?
AliExpress: Maeerxu Flashlight Store - Amazing products with exclusive discounts on AliExpress
Maeerxu XT3- Titanium Anode Camouflage.
Titanium Anode Camouflage Or Blue Anodized Titanium Horse Or Golden Memories
Which one is your favorite?
Maeerxu XT3-Anoded Colored Titanium-Blue Anodized Titanium Horse
● Battery Model: 18350 (Batteries are not included in the package)
● Light bead model :3 * XPL HI or 3 * SS-T20 or 3 * 519A
● Auxiliary light: Light the flashlight for the default seven color light show.
ALiexpress: Maeerxu Flashlight Store - Amazing products with exclusive discounts on AliExpress
Maeerxu DF03-14500 in Brass Three Lamps Flashlight
Maeerxu DF01-18350 in Brass EDC Flashlight
Lamp bead model: 4 * XPL HI or 4 * SS-T20
Copper base plate: electrical separation copper base plate, so that heat dissipation faster
Store: https://www.maeerxu.net/product/maeerxu-df01-brass-18350-edc-flashlight-2/
Nice, I would like to see brass, copper, and possible stainless steel version of this light.
Most of the options I want are listed as “Sorry, no products matched your selection. Please choose a different combination.”
It would be nice to show what is not available, before I click on it. it’s really hard to see what options are currently available.
Don’t worry. These product we are in stock.
Okay,no problem.
Is this light in stock ?
Sorry, this product is out of stock. But we have a product of DF01-18350 Brass.
Good eye Pinky!
Just purchased the DF01 18650 Titanium with Nichia 519A 5700K emitters. Good looking light! Looking forward to it!
Dale
Have you done anything to Upgrade The Switches — A couple of mine don’t work that Good — And the need of that special tool makes them hard to service
Do you sell that Switch Removal Tool
Yes, we have. Do you need this removal tool?
Yes I would like one if the price isn’t too high – Thanks
Do you plan on a DF01-21700 in Aluminum or Brass
Might have to buy another light now :grinning:
Sorry, we don’t have plan on DF01-21700 in Aluminium and Brass currently. We have DF01-21700 titanium natural and Titanium stone. You could think about it.
Oh yeah, could you list that on your site?
Stunning machining on these Titanium lights!
Very nice customer service, very much appreciated!
Ok,no problem. Here is the link for removal tool:
Maeerxu LED Flashlight 4000LM DF02 DF03 DF01 | eBay
If I buy a light can I purchase the tool from your site – $9 shipping for just the tool isn’t going to work
Of course, if you pay twice for shipping after purchasing the flashlight and tools, you can contact our Paypal, and we will refund one.
Y’all are really doing great customer service!
