Hello everyone,
As I mentioned in my “present yourself” post, I am a gemologist. Gemology is the science dealing with gemstones. This includes many different kinds of minerals such as diamonds, sapphire, ruby, emerald, garnet, quartz etc. Most gemstones are appreciated for their color, diamond being an exception. Everybody knows about the red color of ruby, the blue color of sapphire, and green color of emerald. But things are not as simple as red, blue or green, in fact there is an infinite number of different hues, saturation and brightness for each kind of gemstone. See below an example with emerald:
You may have guessed that some colors are rarer, or more valuable than others. For example, a deep, intense “pigeon blood” ruby from Burma can be worth millions, while an under-saturated, light red ruby from Sri Lanka is worth pennies.
One of the jobs of a gemologist is to characterize the color of gemstones in order to assess their values, and trust me this is a real headache. The best way to characterize the color of a gemstone is to use natural sunlight or similar standard illuminants. However they are not always available, like in an indoor gem market or in an office, for example.
Most gemologists carry their own flashlights for such cases, but surprisingly most of the flashlights I have seen are low cri and with horribly high CCT. How can you evaluate the color of a gemstone with a low-CRI light, especially for red stones?
Below are some example of lights used by gemologists and gem merchants to give you an idea. Most of these lights have a cone-shaped head to focus the lights in a very small area. This is very useful to inspect the inside of a stone without any stray lights getting into your eyes, or to inspect the clarity and color of gemstone roughs than are not already cut.
Nitecore Gem
https://flashlight.nitecore.com/product/gem8
Noble flashlights, made by a family in Burma. The link contains a video that shows of the cone-shaped head works
https://joehenleyrough.com/products/noble-flashlight
I personally carry a Nitecore MT06MD with a high-CRI Nichia 219b 5000k with a nearly pure-white tint to reproduce natural sunlight.
But now I want something even better ![]()
So, my goal here is to build my own dream flashlight for inspecting gemstones. One light to rule them all!
The light should have the following specifications:
- 18650 batteries for extended runtime
- E-switch
- Ultra-high CRI emitters, such as Nichia Optisolis. I think Clemence’s MCPCB with 4 emitters very close together is great.
- Two sets of emitters, incandescent-like 2700k and sunlight-like ~6000k
- If there is room for it, a separate SST-10 UV 365nm emitter
- The ability to select between the 2700k or 6000k emitters (for example, the light turns ON on the 2700k, two clicks on the button switches to 6000k and vis versa)
- The ability to ramp the brightness
- The ability to have both emitters ON at the same time and tint ramp between the two à la Sofirn LT1.
- Any kind of frosted optic to remove any weird beam pattern due to the multi-emitter
- Removable cone-shaped head that will sit above the optic in order to inspect the interior of gemstones
Regarding the flashlight body, I can have access to a lathe and design the body myself. Worst case scenario I could use a Convoy host I think.
Regarding the driver… I have absolutely no idea how this works. From what I understand I need a 2 channel driver to control the 2700k and 6000k emitters independently. 3 channels if I want to implement a UV emitter to the mix. I also have no idea how the Nichia Optisolis should be driven. I would need some advice on that. ![]()
Regarding the UI… Again no idea how it works. I could learn how to code a UI myself. I know TK’s Anduril supports tint ramping, maybe I could use that. I would need advice on that as well.
I have good practical and soldiering skills, I used to mod game consoles. I really want to make this project happen, no matter the time or effort it will take. ![]()
If you have any advice, ideas, or comments please feel free to let me know.
Cheers all
