A new game-changing cell for our flashing lights: JP40 (LT21700A) 40A Continuous Discharge Test.
** JP40 (LT21700A) - 40A Continuous Discharging Test**
In this video, I put the Ampace JP40 cell to the test with a continuous discharge at 40A. We’ll go through the performance metrics, including voltage, current, power output, capacity, and temperature changes during the discharge cycle.
Test Details:
  • Initial Voltage: 4.14V
  • Test Mode: Constant Current (CC)
  • Discharge Current: 40A
Key Metrics:
  • Voltage: The cell started at 4.14V and maintained a stable voltage profile throughout the test. The minimum voltage recorded was 2.5V under load.
  • Current: A consistent 40A current was drawn during the test, highlighting the cell’s ability to handle high discharge rates.
  • Power: The power output peaked at 144.21W, demonstrating the cell’s capability to deliver substantial power.
  • Capacity: The total capacity utilized during the test was 4084 mAh, showing the efficiency and performance under high-drain conditions.
  • Temperature: The maximum external temperature recorded was 59.4°C, indicating excellent thermal management and stability.
Summary:
The Ampace JP40 cell performed exceptionally well under continuous 40A discharge, maintaining stable voltage and temperature levels. This test showcases the cell’s robustness and reliability for high-drain applications, making it a suitable choice for demanding projects.
Test conducted by: Nelvick Berrios
Please subscribe to my channel.
For a detailed breakdown and further insights, make sure to watch the full video!
You can get this cell from this link. Ampace JP40 21700 4000mah 70A Battery - Tabless Cell
6 Thanks
Thank you for posting these test results! It’s great to see stuff like this being done.
This cells will be awesome with my imalent MS18. I need to modify the tube.
Thank you for sharing this test with us!
Were these sourced from https://18650-21700.com/ ?
Thank you, I was looking for the source. I ordered a few to compare against 40T and P45B in a HK08.
Just saw a post on the VESC group confirming that Austin at 18650-21700 sent these over. Do you know where he is sourcing them? The only place I have found to buy them is Alibaba and I don’t really trust those cells yet.
I tested two of these:
@1A 4135mah
@3A 4108mah
The cells are available on my site. JP40 (LT21700A) - Limited quantity available and large stock coming so
For anyone interested, the guys over on the Torque Test Channel compared packs built with these cells, using a high torque impact wrench on a calibrated precision torque dyno. I wont give up the comparative test result here, but its worth watching if you are considering buying some JP40’s.
Here is another test I performed on the JP40 cell, draining the maximum current it can provide—108A, from a single cell.
In the video, I also conducted the same test on a Molicel P42A.
The ampace JP40 seems to be the best high-drain 21700 in the world currently. I have watched a lot of tests, and it beats every single competitor. Sadly, you can’t get hold of any in europe yet.
I can help you with that.
I doubt you can ship to my country for a resonable price in the low quantity I want, but I can send you a message.
18650-21700 is finally shipping to europe! Shipping only costs… 138$… ups
The Cells are in stock rights now with the best pricing. JP40 (LT21700A) - In stock - 20 cells or more Free Shipping !!
Will be nice if anybody share experiences. I want to share the last video testing with the new Attorch high current holder with my DL20EW tester at 40A CC. Check the thermal performance of these cell and capacity at that load.
Pls check your 4-wire connection to the tester. (You can use an ordinary voltmeter for check, just connect its probes directly to the cell terminals and compare both readings under the load) Your measured voltage sag is too high for this cell, even at 10C@40A you still should be above 3.75V right after applying the load and get at least 13.6Wh with this settings.
I believe in this case is suffering from voltage drop since the device is made for only 20A. 40A probably is overheating and creating the sag. However, the sensing wires should not be affected for this. I need to see if the meter need calibration or upgrade the wires. Now I have a better option than this one for high current testing.
Pajada, I hear so much about you and Is my pleasure know you now. Thank you for your advice !!!
