【AA Headlamp available with 519A LED】Acebeam H16 ultra-lightweight AA 519A LED Running Headlamp, 15%OFF on AliExpress!
It is the first high-color-rendering AA running headlamp on the market that uses a 519A LED which produces a 5000K, uniform, and full large beam. The light is soft, comfortable, and non-glaring. Compatible with the standard AA battery, which is reliable, inexpensive, and easy to find. Can be firmly attached to a metal surface with a magnetic tail or clip in your pocket as a chest lamp, offering various lighting demands.
Also, a high-power 1000 lumen 6500K version is available for users who pursue high brightness.
It is now officially available on AliExpress official store!
Check now→15% OFF On AliExpress!
Follow the Store to Get the Extra Coupon!
Features:
Available two for option:
H16 Black: 1 x 519A Neutral White, Color Temperature 5000K, High CRI90, Max Output 650 Lumens, 100° Wide Range Flood Beam;
H16 Gray: 1 x Cool White, Color Temperature 6500K, Max Output 1000 Lumens, 110° Wide Range Flood Beam.
Included one 14500/Type-C rechargeable Li-ion battery
Compatible with one AA Alkaline or NiMH rechargeable battery, wide range of Voltage design: 0.9V~4.2V
Durable tempered glass lens with AR film plating for scratch resistance, light transmittance reach up to 99%
High efficiency constant current circuit board provides maximum runtime of 58 hours
Low-voltage warning design
One switch controls 5 brightness levels and 1 special mode sos
Comfortable fit provided by the ergonomic adjustable headband (Included)Reflective headband to remain visible at night
Two-way body clip capability for varying conditions
Magnetic tail hands-free fixation
Premium type HAlll hard-anodized anti-abrasive finish
IP68 grade (2 meters submersible)
lmpact resistance 1.5 meters
Special design for running, camping and harsh outdoor environments
H16 Black Version - 519A LED | 5000K | CRI 90 | 650 Lumens
H16 Grey Version - 1000 Lumens | 6500K | 110° Wide Flood Beam
Other Common Features
Not bad. :slight_smile: I wish it came with Andruil though… :slight_smile:
