accidental NiMH torture test, PKcell
Interesting. I got one of those sprinkler timers to top off my Olympic Size Birb Water Park™, 1min a pop for 4× per day. Ran several months and then stopped filling.
Was using PKcell NiMH cells in it. Of course, showed low battery right from the gecko :lizard: but worked great.
So I pop em out to recharge them. Zero. Zilch. Nothing.
Got a dedicated NiMH charger, nothing. Stuck em in my Opus, nothing. Stuck 1 at a time in my LK101 or whatever, nothing. Tf??
Measured the voltage on each… showed “095” that I saw. Angle and dim lighting, couldn’t see the actual decimal point, so no idea if 0.95V or .095V on the 2V range. Probably the latter!!
So had an idea… both the Ope and NiMH charger had 0V when live but no cell in the bay. They must need to sniff an actual voltage from a cell before starting.
The LK, though, showed 4.7somethingV with no cell, so it must apply a weak voltage (slow start?) and count on the cell pulling down that voltage to sniff what type of cell.
So, genius that I am, I figured let me just leave the little beastie in the charger and see if the trickle might pull up the cell’s voltage, enough to get it charging.
And it worked!
It started charging, and after a while, pulled each in turn and stuck them in the Ope for a capacity test.
Rated 1300mAH on the label, and the first round clocked them in at 1044 and 1139. Running a second captest right now.
These little beasties had a bunch of cycles already in other goodies, and with pretty much shorting em dead, I didn’t have high hopes for them. Glad to see they can revive nicely.
Second run finished, pretty consistent.
1034 & 1041.
1139 & 1151.
I have some of those. They’ve turned out to be one of the better ‘experiments’ into AA alternatives.
For over discharged cells I’ve kept a couple old ‘dumb chargers’ to kick start them. 90% of the time that works. If it doesn’t I consider them dead.
Yep.
And I found an EBL loosie, ie, not part of a pair. Run down, but it clocked in at 1850mAH, 2300 on the label.
Don’t think I ever got any NiMH cell even close to what was on the label, so these might very well be “good as new”. :joy:
I use this to charge up the dead ones, it used to be you could order them from China for 79 cents shipped.
AA / AAA USB NiCd & NiMH Stick Battery Charger
“enelong”… :joy::skull_and_crossbones::joy:
“Enelong”, the best buy batteries!!! Loop versus Long, very best Long!!! :joy:
(Be careful with modern chargers; they are far worse than older ones when it comes to “reviving” batteries. Never throw away old chargers—they can always be used to revive batteries, whereas modern chargers are all junk and simply cannot do the job.)
That was very clever. You deserve an E-pat on the back.
