MSRP: $159
Sales is as is!
I’ll be posting a lot more lights; around 40 more soon. So to save time, I’ll upload actual photos upon request.
Batteries not included!
The Acebeam K30 is a compact, high-output “beer can” style LED flashlight delivering up to 5,000–5,200 lumens, powered by three user-supplied 18650 Li-ion batteries. It features a side-switch user interface, a built-in battery level indicator, and IPX-rated water resistance.
Key Specifications (Original Acebeam K30)
• Max Brightness: ~5,000 to 5,200 lumens
• LED / Reflector: Single high-output emitter (such as Cree XHP70.2) with a smooth reflector
• Battery Configuration: 3 x 18650 Li-ion batteries (button-top, protected recommended)
• Battery Indicator: Built-in LED status light (Green: >10.5V, Constant Red: 10.5V–9.5V, Flashing Red: <9.5V)
• Modes: Multiple brightness levels (ranging from a low firefly/moonlight mode up to Turbo/Turbo Max) plus a strobe mode
• Switch: Single electronic side switch with mode memory and direct access to low/turbo
Acebeam K30-GT Variant
If you are looking at the long-range thrower version, the Acebeam K30-GT upgrades the setup:
• LED: Luminus SBT-90-Gen2
• Max Output: 5,500 lumens
• Max Beam Distance: 1,024 meters (over 1 km / 3,360 ft)
• Power Source: 3 x 18650 Li-ion batteries
• Modes: Eco mode and Power mode switching, side-switch operation, and strobe
• Weight & Dimensions: ~336g (without batteries), length 155mm, head diameter 57mm
