Acebeam X65 12000 Lumens 1301 Meter throw
Acebeam reports on there site that they will come with a X65 10.000 11150 12000 lumen 1000m 1150m 1301m throw flashlight with 5x Cree XHP35. WOW :sunglasses:
Link to Acebeam X65
They have updated there specs.
5*Cree XHP35 High Intensity LED with a lifespan of 50,000hours
2:Max Output 12000 lumens Use 8*18650 battery
Firefly : 4 lumens 150hours;
Low : 500 lumens 28hours;
Mid : 1500 lumens 8hours;
High: 3500lumens 3hours;
Turbo:6000lumens, 2hours
Turbo Max:12000lumens, 1hours
3:Working Voltage:12V-16.8V
4:Max Runtime 150hours
5:Max beam 1301 meters
6:Peak beam intensity 423000cd
7:Impact resistant 1.2meters
8:Waterproof :IPX-8 Standard (2meters)
9:Size:276mm (Length)*108mm (Head)*51(Tube)
10:Weight 1290g (included battery)
11:Smooth reflector gives perfect beam and throw.
12:Digitally regulated output- maintains constant brightness
13:Side switch on the body
14:Over-heat protection to avoid high-temperature of the surface
15:Made of durable aircraft grade aluminium
16:Premium Type III hard-anodized anti-abrasive finish
17:Toughened ultra-clear glass lens with anti-reflective coating
INCLUDED ACCESSORIES:
1x user manual;
1x lanyard;
1x warranty card;
1x Replacement O - ring ;
1x AC/DC adapter ;
The throw 1301 meter funny not 1300m but 1301m
Wow.
Is it 5 or 4 emitters? The picture looks like 4
Wonder if it’s the X60 reflector 5 emitters….2000lms @?
I counted 6 reflector sections. It will be good to see.
Interesting!!! :sunglasses:
I wonder if they used the old X60 Charging mechanism that gave so much problems in the past or did they switch to something better?
hopefully there is no tail switch also…
looks like no more magnetic selector ring
good job acebeam…i prefer just a side clicky.
I hope it is not the more expensive rechargeable one with battery included.
It looks like the handle can take 8x 18650 cells.
I think it is also wisely with 5x Cree XHP35. The drainage on Turbo will be very high.
At the X60M after 2 minutes turbo shuts down to 4000 lumens.
For me, the only reason I use the X60 is because of the selector ring!
+1
but I think, due to one member here bashing them constantly over mishap in charging circuit (that they corected), they will not cooperate with BLF anymore… :confused:
Increased to 11150 lumens
now that is a monster.
:smiley:
Mmm that looks like a lanyard attachment point, not a side clicky. Unless you have a different picture I don’t
MICROBLUEBEAR!
So it begins… :smiley: :+1:
In before the MAP
I’ve readed on a German forum that Acebeam will charge $500 for this light, accupack and charger included. Pfff that’s a lot of money for a flashlight.
And people would still buy it
$500? I recoil from it as from a hot flame. Pun not intended.
